DIY Stompboxes => Building your own stompbox => Topic started by: O'malley's Alley on May 04, 2004, 04:01:34 PM
Title: Help me redisign this schem...
Post by: O'malley's Alley on May 04, 2004, 04:01:34 PM
I want to use a blinking led schematic for something I am building (photo resistor content stuff)  I took the blinking LED schematic from the 4ms tremulus lune, and it looks like this:
(http://img32.photobucket.com/albums/v95/mancubus/blinking_schem.bmp)
however, I do not want all those pots in there, just the speed one.  How can I redraw this to not have all the pots in it.  Or if anyone has a better blinking LED schematic with just a speed knob that would be much appreciated.
Post by: O'malley's Alley on May 04, 2004, 04:02:45 PM
sorry, better pic:
(http://img32.photobucket.com/albums/v95/mancubus/blinking_schem.jpg)
Post by: axr on May 04, 2004, 04:07:00 PM
http://www.commonsound.org/other/audiolfo.gif
Post by: O'malley's Alley on May 04, 2004, 04:12:38 PM
Quote from: axrhttp://www.commonsound.org/other/audiolfo.gif
Im just looking for a LED schem, not anything that is audible.
Post by: RDV on May 04, 2004, 04:17:33 PM
Courtesy of Joe Davisson
(http://analogalchemy.com/pedals/metronome.gif)
RDV
Post by: O'malley's Alley on May 04, 2004, 04:23:41 PM
Thanks.  What does the switch do to the circuit?
Post by: RDV on May 04, 2004, 04:26:01 PM
Look again.
RDV
Post by: O'malley's Alley on May 04, 2004, 04:27:43 PM
ok thanks.  can I just not wire in the speaker and just have the LED circuit?
Post by: RDV on May 04, 2004, 04:37:55 PM
Quote from: O'malley's Alleyok thanks.  can I just not wire in the speaker and just have the LED circuit?
I think so. I thought this might be closer to what you were looking for. You might not even need the cap, but I'm not sure.
RDV
Title: I got one around here
Post by: petemoore on May 04, 2004, 05:37:58 PM
Ansil posted the schematic.
 Used a 555, and like four or five other parts, one being a 100k V/R speed adjuster, also the cap could be changed for wider speed ranges, IIRC the pot does about a 4X speed adjust range.
 I don't know if I can find the schem, but it's around here somewhere, only a few connections besides V+ and Gnd.
 Might click on same PS as an audio path OA er what, I was going to run separate supply for the blinker, if it did [and probably would] click.
Post by: Paul Perry (Frostwave) on May 04, 2004, 07:59:57 PM
I think you will need the speaker, but you can replace it with a low value resistor. Without the speaker (or resistor in that position) there is no feedback, and hence no oscillation, if my analysis is correct.
Post by: O'malley's Alley on May 05, 2004, 05:28:58 PM
does anyone have any IC based schems?
Post by: Torchy on May 05, 2004, 06:21:06 PM
http://www.uoguelph.ca/~antoon/
