I know there is a commercial pedal whose name is escaping me that does this. It uses a wah enclosure to blend between two chains of effects. I remember at the time it was being discussed that people made that process out to be somewhat difficult. I was thinking about this today and trying to imagine the pitfalls of this design.
Originally, I thought a single pot would take care of it, as in most blend pots. One effect in 1, the other in 3, and then the output in 2 from an appropriately large pot. I suppose a potential problem there would be impedance against the "tuned out effect". Forgive my stumbling incomplete knowledge of impedance.
But then I thought, well, couldn't you just use a dual ganged pot so that each effect loop gets thrown to ground when it's tuned out? Is there some difficulty here that I am missing? Is the interaction between these two effects more than could be dealt with a simple summing amp?
Check out RG's panning for fun article. I used this recently and it works a treat (thanks RG!).
Another option is the Splitter-Blend at runoffgroove.com...
I managed to fit a rocker assembly to turn the pot Via Treadle pedal in a Large Raco.
Hoooo Yeahhh...Mixed signals and smoooth transitions !!
Lead Boost if needed is right /there.
It was a SOB getting the treadle and clock spring takeup reel in there 'Jethro Bodine/Mcgyver Style'...it's made it through many races, it is deemed 'worthy'....when I was building it I said to myself "I Dunno.." :?
Starting with a long case, a simple spring take up tensioner for the string driven pot pulley [like on ernie Ball Volume pedals] would make it easier to manufacture.
