DIY Stompboxes => Building your own stompbox => Topic started by: ryani on May 11, 2004, 01:30:23 PM
Title: led mounting
Post by: ryani on May 11, 2004, 01:30:23 PM
I really like the way the led's on zvex pedals are mounted with no bezel and the tip of the led just sticking up out of a hole in the enclosure.  Does anyone know of a good way to secure led's this way? Thanks
Ryan
Title: led mounting
Post by: markusw on May 11, 2004, 01:46:48 PM
I suppose he mounts them directly to the PCB. But there are also small rubber sockets you might want to use.
Title: led mounting
Post by: dosmun on May 11, 2004, 02:27:05 PM
A glob of Silicone or Hot Glue or similar products should do the trick.  Also make sure you drill the hole so the LED fits in snug.
