I was looking at David Gilmores guitar's internal setup in an old issue of Guitar Shop today. He uses EMG's SPC mid booster and the EXG mid cut/expander. I've recently put a Stratoblaster in my guitar and really like it so far, but I thought some sort of active tone control might be cool. Are there any schematics around for stuff like this that might fit in the guitar cavity?
I think Aron has a couple of variants of the Fender Eric Clapton Strat circuit, which includes a buffer/preamp and a variable mid-boost. It is not as compact as the EMG, IIRC, but definitely along the same lines. Also, so a search for Craig Anderton's mid-boost, the basic schematic for which is floating around (and also found in one of his books).
Hope this helps.
Ben
There were a couple of schematics relating to mid boosts etc at the Blue Guitar page, I believe the Clapton one was also there
If you use small caps and 1/8W resistors, you can fit the EC Strat circuit in 2 square inches of stripboard. I have a homemade one in my Strat, tone is good but it's noisy.
CD:
Hey, I'm curious about the details--how'd you mount it? Did youi have to rout at all? Where'd you put the battery(ies)? Did you do the original circuit, or the op-amp variant? Got pix?
Ben
Quote from: Ben NCD:
Ben
The fit was still tight, so to "mount" it all I did was to stuff it in a plastic bag (so nothing shorted out) and it fit in the standard Strat routing for pickup selector switch/pots. I put the battery (a single 9V) behind the tremolo block - I play with a blocked trem (like on the EC strat) so I got rid of the block of wood I had there and replaced it with the battery and another smaller piece of wood as a shim. I did it this way for ease of battery replacement (though the battery lasted a really long time) and I don't think there's enough room for the battery inside the existing routing. I used the original discrete circuit (with 3904 and 5807) not the opamp version. Sorry, no digital camera so no pix :(
You can get the EC cicuit here http://home.rochester.rr.com/dallard/guitar/review/clap.htm
can you help me out on which transistor goes where, Q1,Q2.Q3,Q4 ?
Thanks,
JD
The PNP is a 5087, the NPNs are 3904.
