DIY Stompboxes => Building your own stompbox => Topic started by: mikeb on May 11, 2004, 08:02:45 PM
Title: Transistor for EH Hog Foot
Post by: mikeb on May 11, 2004, 08:02:45 PM
Anyone built this? 2N5133's seem to be pretty thin on the ground, wondering if a 2N3904 would be a good sub? I've got a 2N5088 in there now, and the boost is fine, but I'm really after the 'compress / fuzzy' sound that Charlie describes on his build page for it. With the 2N5088 it doesn't seem to matter if the 43k/39k resistor to ground is switched in circuit or not! :?
Mike
Title: Might I suggest...
Post by: petemoore on May 11, 2004, 08:47:38 PM
BCxxx, I think these sound alot like what you described, however, tried in an LPB, with different value input and output caps.
 As much 'different' sounding as any NPN type I know of in a circuit like this.
 5089 might give a better performance than a 5088 in this circuit, and could also be lower noise.
 You can chain more than one of these circuits, and use the 1rst stages volume control as a gain control for the second stage, possibly trim the value of the stage 1 vol pot.
Post by: moosapotamus on May 12, 2004, 09:44:58 AM
Hi Mike,
It's been a couple years, but I think I just used the NTE equivalent in my Hog's Foot... NTE161.
best
~ Charlie
Post by: mikeb on May 12, 2004, 05:06:50 PM
Pete - thanks, but I want to get this circuit working exactly the way Charlie did, and the way it sounds on the sample! :)
Charlie - thanks also, I'll see what I can do.
Cheers
Mike
