DIY Stompboxes => Building your own stompbox => Topic started by: Torchy on May 16, 2004, 08:31:48 PM
Title: Easyvibe PCB - Well Chuffed
Post by: Torchy on May 16, 2004, 08:31:48 PM
OK, heres a piccy of my Easyvibe ready to be boxed. First thing bigger than the Nurse Quacky and only the third pcb I ever made. Worked first time as well  :o
(http://server5.uploadit.org/files/Torchy-Phot00026.jpg)
Post by: nirvanas silence on May 16, 2004, 08:57:35 PM
What LDR did you use?  Looks really nice.
Post by: Jim Jones on May 17, 2004, 10:03:37 AM
Great job!
I'm just "rediscovering" my Easy Vibe - it's a fantastic sounding circuit!
Jim
Post by: Samuel on May 17, 2004, 10:16:53 AM
you find the led/ldr combo works w/o light shielding?
Post by: Torchy on May 17, 2004, 12:05:09 PM
Thanks, bit more complicated than fuzz etc but turned out ok  :wink:
The LDRs are a job lot I got (bag of 40) from ebay. Go down to ~7k and work ok. Needed to cover the whole thing while playing with the drive preset but as long as the box is lightproof I think it'll be ok.
Right, now for the Tremulus  :lol:
Post by: RDV on May 17, 2004, 01:41:18 PM
Quote from: TorchyNeeded to cover the whole thing while playing with the drive preset but as long as the box is lightproof I think it'll be ok.
You'll need to encase them somehow. I made the mistake of not shrinkwrapping them also. Till you can isolate them from one another almost 100% you'll never hear the circuit as intended. The 2 LEDs(for OA bias?) that are by themselves will mess up the sweep worse than anything. If you use an LED for an on/off indicator, that will wreak havoc also. I've got mine(LED/LDR combos) all sealed with electrical tape, but it has to be checked all the time as it is always coming off, and I really screwed up not doing it right in the first place(in a hurry).
Regards
RDV
Post by: Torchy on May 18, 2004, 04:18:46 AM
Thanks for the tips. Once Ive got the box sorted I'll isolate them properly as you suggest. Never thought of sealing the bias LEDs though - ta  8)
Post by: RDV on May 18, 2004, 06:02:01 AM
If you seal the others properly the bias ones won't matter. My problems arose from the fact that I didn't properly seal the LED/LDR combos. So then every light source becomes a problem.
Regards
RDV
