DIY Stompboxes => Building your own stompbox => Topic started by: ExpAnonColin on May 19, 2004, 01:10:21 AM
Title: Will someone with an LM386 try this out for me?
Post by: ExpAnonColin on May 19, 2004, 01:10:21 AM
(http://www.experimentalistsanonymous.com/other/bipolarsupply.gif)
Will someone put this circuit on a breadboard?  I have misplaced all of my LM386's somehow...  First try testing the points labled +Vs/2, 0v, and -Vs/2 in reference to the circuit's ground, then try testing it using the LM386's output (pin 5) as a reference and let me know what you come up with.
Thanks a bunch.
-Colin[/img]
Post by: claydavis on May 19, 2004, 09:48:34 AM
my breadboard is full right now (with a 386 circuit, coincidentally), but if you send me your address i'll drop a 386 or 2 in the mail to you.
-clay
fma069@hotmail.com
Post by: Hal on May 19, 2004, 10:28:59 AM
...when i get home, i'll do it...
what are pins 2 and 3 connected to...nothing ?
And what do you want tested, voltage...?
Post by: ExpAnonColin on May 19, 2004, 10:30:31 AM
Quote from: Hal...when i get home, i'll do it...
Yes, and yes.  Sorry if I didn't make that clear.  And if you could, try it with nothing in the pin 1-8 loop, too, because now looking back I think that that shouldn't make a difference.
claydavis-Thanks a ton, but I'm sure they're around somewheres... if not I'll just get some in my next sample order from National.
-Colin
Post by: Hal on May 19, 2004, 06:55:10 PM
works, colin, and well at that...
I'm reading slightly less than +/- v/2, but i think thats normal.   I was reading about +/-2.3v, and thought that was bad, until i realized my 9v was reading only 5v  :x So I guess there has to be a slight voltage drop somewhere, but thats pretty good :-D
Instead of the pot, i used 2 430k resistors...But besides for that, i used all the same parts.
Little to no differance between with the stuff between pins 1-8 and without.
Still on the board if u need anything else...
Post by: ExpAnonColin on May 19, 2004, 10:16:52 PM
Thanks a ton, Hal, glad my idea worked...  (Revises circuit, posts new thread)
-Colin
