DIY Stompboxes => Building your own stompbox => Topic started by: crawler486 on May 19, 2004, 01:30:09 AM
Title: Noise problem...
Post by: crawler486 on May 19, 2004, 01:30:09 AM
I got 5 cloned effects in one enclosure being supplied
by "9v Ultra Clean Power Supply" from GGG.
I'm just wondering why there is a very noticeable noise swell
when I put the enclosure to the ground. The enclosure
when placed on a table has an acceptable level of noise.
The base of my enclosure is made from plywood with
aluminum sidings and top cover.
Any idea?
Thanks.
Post by: Travis on May 19, 2004, 02:01:57 AM
Shield the bottom. Use foil, fine meshed screen, whatever.  Report back after that.  If you only want this pedal for bedroom usage, you might be fine; but I'd definitely shield it for gigging.  Clubs have a nasty habit of actvely wiring in an unpleasant, aggressive manner.
Post by: crawler486 on May 19, 2004, 02:08:30 AM
Shield the outside bottom, or the from the inside?
Post by: Travis on May 19, 2004, 03:51:49 AM
It doesn't matter, as long as the circuit is completely enclosed, and the entire shield is grounded.
You might also try to find out what is causing the interference.  There is a spot in my house that has so much crap in the air that I can't run any signal near it, shielded or not.
