i wanted to know if you all could help me. what is an LDR? what does it do? what does LDR stand for?
i had seen them in a couple of schematics recently and i wanted to know what they were used for.
thanks so much.
javascript:emoticon(':wink:')
Light-Dependant Resistor. These can be used in combilation with LEDs or standard incandescent bulbs to provide an isolated variable resistance, such as in phase shifters. There are alot of commercially-available components that have a pre-assembled LED and LDR in a package called an optoisolator or optocoupler. Alot of diyers will jus use a LED/LDR pair - usually cheaper '8)"
Here is what a typical unit looks like...
(http://edge.mcs.drexel.edu/assemblies/tests/assemblies-200209/cds-cell.jpg)
Take care,
-Peter
It is a resistor which resistance varies depending from how much ( or how bright) light it receives. LDRs I have encountered are MORE LIGHT=LESS RESISTANCE.
Compressors and wah (Morley) are just two effects where you can usuallly find it.
Wasn't LDR one of the presidents?
:wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink:
RDV
Yeah, Larry D. Roosevelt... :D
Regards,
Lone
Have you not heard of the Church of Latter Day Resistors!
is it possible to use a GWB in a LoFi pedal? :cry:
HAHA
its the new LoDow pedal :)
so does that mean they are the same thing as photo resistors?
yup!
