DIY Stompboxes => Building your own stompbox => Topic started by: Brian Marshall on May 26, 2004, 02:30:55 AM
Title: dark tshirt transfer.
Post by: Brian Marshall on May 26, 2004, 02:30:55 AM
ok, i went and got my avery transfers, and printed them out.
I see a bunch of vertical lines on them....  even before printing.  i thought maybe they would go away after they were ironed on.... no such luck.
maybe ill make some cheesey t-shirts or something.... i dont think they look very good.
Post by: maximee on May 26, 2004, 08:29:50 AM
those transfer printout thingies worked just great for me...
so i would suggest you check your printer...
i suspect your problem to be a mis-calibrated inkjet printer...you might want to check the printer manual how to clean and calibrate your printer...
that should pretty much do it.
i hope i did get you right on that one :)
good luck!
Flo
Post by: Brian Marshall on May 26, 2004, 11:37:00 AM
no no no no... you misunderstand... the lines are on the paper before i print..... looks like a texture, or watermark on the paper its self.
Post by: Samuel on May 26, 2004, 11:55:13 AM
maybe you got a bum pack? I had no such issues with mine...
Post by: Brian Marshall on May 26, 2004, 12:02:49 PM
they look to be textured like potatoe chips  :x
Title: hmm
Post by: petemoore on May 26, 2004, 12:07:03 PM
I 'think' the grid side should be on the 'other side???
 There's these 1'' squares gridded across 1 entire side of the the transfer sheets, is this what you're seeing? I think the ink is to be applied to the opposite side...
 OR, I could be misunderstanding the questions about your problem///
Post by: Brian Marshall on May 26, 2004, 12:25:32 PM
I am not printing on the grid side.... i read the insturctions, and have transfered a couple already.  the problem is the tranfer paper it's self.  u can see the lines on the papaer before you print.  I tried printing darker.... didnt come out any better.
The transfers appear to have a texture, or watermark, of vertical lines going up and down the page.... space between lines is about 1/16 of an inch or so. totally consistant on all pages.
they are the only avery dark t-shirt transfers i saw.  I dont think i bought the wrong stuff...
ill take a pic tonight to show u what i mean.
