hello people,
i need a 560pf cap but i cant get one is there any others i could use instead???
it would be helpful if i could use the equivilant of that value in uf but i dont know what the equivilant would be........ help!!
thanks
eamonn.
There you go.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=40113&item=3817527423&rd=1&ssPageName=WDVW
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=36335&item=3818086453&rd=1&ssPageName=WDVW
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4662&item=3802235639&rd=1&ssPageName=WD1V
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4662&item=2566315973&rd=1&ssPageName=WD1V
.00056 uF
http://www.bcae1.com/milli_.htm
Cool?
Quote from: el duderinohello people,
thanks
eamonn.
It should be 0,00056uF. Someone correct me if I'm wrong.
Parallel and series man! just hook some smaller or bigger(series) caps up to make the value you want. I think (not sure at all) that series is add togetther values(for two) and divide by four. parallel adds the values.
1Farad =
1 000 uF(microFarad) =
1 000 000 nF(nanoFarad) =
1 000 000 000pF(picoFarad)
560pF could be marked 561, .56nF, .00056uF.
When you just have 3 numbers on the cap, the first two are the value, and the last one tells you how many zeros to add after it. 561 = 56 + one zero = 560pF; 223 = 22 + three zeros = 22 000pF or 22nF or .022uF.
I wrote a bunch of zeros on a sheet pinned to my wall:
000|000|000|000
....F.....u.....n.....p
(each unit is under the last zero of its group). It made it easier for me to put any value in uF, nF, pF etc.
Hope that helps.
