DIY Stompboxes => Building your own stompbox => Topic started by: jimmy on June 13, 2004, 04:36:30 AM
Title: BSIAB Gain q
Post by: jimmy on June 13, 2004, 04:36:30 AM
hi everyone
just finished buiding a brown sound in a box from GGG, after listening to the soundclip at diyguitarist.com. it worked after a few bugs were ironed out (i had two seperate ground points, and two components hadnt even been soldered together  :? )
end result - an overdrive pedal! problem is, it has very little gain. id say just less than a tube screamer, much different from the soundclip.
now ill put this down to the fact that i used MPF102s instead of the ever-evasive J201s. ive read the J201s are higher gain, but is there that much of a difference?!?!
if this is the case, any tips on how to supercharge it up to a higher gain beast? only idea i had was sticking bypass caps on the bottom fet in the minibooster stages. will that work?
Jim
P.S. also built Fetzer Valve - ROG strikes again! great work guys!
Title: Re: BSIAB Gain q
Post by: Eric H on June 13, 2004, 06:47:05 AM
Quote from: jimmy
In general, yes. If you want to hear this effect the way it was designed --get j201's.
Quote from: jimmyif this is the case, any tips on how to supercharge it up to a higher gain beast? only idea i had was sticking bypass caps on the bottom fet in the minibooster stages. will that work?
Yes, and you have a golden opportunity to learn something, too.  Try different sizes of bypass caps (,01uf to 22uf) to vary the bass content.  You can also add 100k (or so) trimpots wired as variable resistors inline with those caps to vary the gain.  You can lower the resistance (or remove completely) the 470k/470p between the boosters. Lower the value of the 100k going into the buffer.  Try one thing at a time, and have fun (get j201's)
-Eric
Title: IIRC
Post by: petemoore on June 13, 2004, 07:09:49 AM
And If I do, check GEO 'create your own Mu Amp'.
 That said, IIRC it's a 1k resistor between the bottom jfet's D and top Jfet's S that improves impedance and gain.
Title: BSIAB Gain q
Post by: jimmy on June 13, 2004, 07:28:11 AM
thanks guys!
Jim
Title: BSIAB Gain q
Post by: YouAre on June 13, 2004, 10:20:03 AM
Its a huge damn difference. I changed one of the j201's to what you had, just ONE out of the five, and i saw a considerable difference.
Post by: Gringo on June 13, 2004, 10:59:35 AM
Take a look at this too:
http://www.diystompboxes.com/sboxforum/viewtopic.php?t=21299&highlight=mpf102+supercharge
Hope it helps.
