DIY Stompboxes => Building your own stompbox => Topic started by: Lee on July 21, 2004, 01:16:52 PM
Title: Long Time No See`haha
Post by: Lee on July 21, 2004, 01:16:52 PM
Forgive me Gentleman~~I`m gonna post something that not about effects`But anyway  ,I have alreaday made a DIST effect myself--The Sans Amp GT2 ,and it sonds realy good.:)   I spent nearly half a year to built it because  it aways had noise ``but now the problem has been solved:)
I ..``  In fect  ,I wanna make friend with you all !
Here is my ICQ ````253448790  :)  I`m watting for u!
Post by: Athin on July 21, 2004, 01:26:49 PM
what was wrong with it?
Post by: Marcos - Munky on July 21, 2004, 01:43:34 PM
Hi Lee. Welcome. You started with the GT-2? Wow, then you won't have difficulty to build effects!!! I don't have ICQ, but you can e-mail me any time.
Post by: Lee on July 21, 2004, 03:07:23 PM
All right!!  :)  My E-MAIL :liqunchao_002@hotmail.com
Let me tell you a secret,and don`t tell others haha ``I `m just a guy who only konw how to see the schm but don`t know how dos the circuit works at all:twisted:
The first one I made had too much nosie-----the schm I useed was one which download from ???site (thanks a lot). But now it was substantiated by one person that it has no problem.That means I made the problem
Then I decided to make the second one and make a PCB myself .I made the PCB had two part,one had  all ICs on it ,  and also I/O jacks,DPDT switch,then use cables conect eachother .Here is the photo of it  !
http://www.longzu2002.com/bbs/dispbbs.aspboardID=1&ID=1104&replyID=8182&skin=1
Although it could work,but still have error .I check the PCB N times,but found no error,I think it should be component`s problem.It must  had a broken one
This is  the third one! -----Hand-drawing
http://www.longzu2002.com/bbs/dispbbs.asp?boardID=1&ID=1467
And
http://www.longzu2002.com/bbs/dispbbs.asp?BoardID=1&id=1467&replyID=11269&star=2&skin=
The photo is at the end of the page .Just pull down.
This time ,I use an analog switch(right?I don`t know too much words.I mean it was built with FETs and Transistors),and use a jumper so I can test the whole circuit.This was better  than the two I `ve made.It just has a little problem-----The analog bypass switch part.When in jumper mod,it has a noise that nearly NONE .But in switch mod,it has a great deal of noise,even a Noise Gate could not reduce it. I was failed.N days passed....
I still have no idea to fix it .Since one day ,I saw the BOSS DS1 schm,I found that the ANALOG sw part should be use like this-----switch the low gain part .I used the ds-1 `s SW part,just like the way it is .It worked!
haha
Now I am making the fourth one based on the second .
Post by: Lee on July 21, 2004, 03:14:10 PM
I don`t know if you could visit this site or not.It is an simple chinese one
Post by: Lee on July 21, 2004, 03:28:09 PM
Those was two effect I have made```Don`t laugh me``:)
Marshall `s Guvnor
http://www.longzu2002.com/bbs/dispbbs.asp?boardID=1&ID=1269
Zombie Chorus
http://www.longzu2002.com/bbs/dispbbs.asp?boardID=1&ID=1338
And a metal box
http://www.longzu2002.com/bbs/dispbbs.asp?BoardID=1&replyID=10348&id=1360&star=1&skin=0
Post by: Marcos - Munky on July 21, 2004, 03:31:11 PM
I can't see the first two, but I liked the third a lot. What kind of ICs did you used?
EDIT: this was for the first post. I didn't found the photos for the Zombie and Guv'nor.
Post by: Lee on July 21, 2004, 03:38:33 PM
TL072
I could E-mail you the pic if you wish```:)
Post by: Marcos - Munky on July 21, 2004, 03:42:21 PM
Cool. I'm sending a e-mail for you.
Post by: Lee on July 21, 2004, 04:23:08 PM
I sent 5 pictures to you``:)  Thank you a lot  ~~I `ll try my best when you need help `:p
Post by: travissk on July 21, 2004, 04:57:02 PM
You started with the SansAmp?  :shock: Congratulations is all I can say!
From now on, we should suggest the SansAmp to any beginners just wanting to get started  :twisted:
Post by: Athin on July 21, 2004, 06:39:08 PM
I did the same (started with the SA), worked the 2nd time  8)
