Hi all:
I just finished ad-3208 few days ago,and it sounds great! After finishing it,I want to do some mod on it. So I follow the mod on GGG --lower the resistor connect to pin 12 of SA571 to do more repeats. After I change the resistor ,this stuff dont produce delay sound :cry: .I trim the pot to adjust the Bias of MN3205,but how matter I trim, it wont work.So I change back the 100k resistor ,trim the pot,still dead... :shock: Does anyone knows the bias voltage of the MN3205? I've try for 4,5 hours ,and it deosn't work ...can anyone helps? thanks!!
Vbias = Vdd/2;
Vgg = 14/15Vdd;
Is the Vbias=Vin? thx~
it`s the one that is adjustable in the AD3208, at the input of each BBD.
Quote from: nedyoungHi all:
hello !!
I put together a AD3208 from GGG with 02 mn3205, but I cant find them anymore, so I thought I could use 4x BL3208 to get the same 600ms... do you thinks this is possible ??
do you have another idea??
thanks !
its possible, but having 4 more trimpots will make calibrating it tough !
just send the signal output from the last 3208 into another 3208 like what has been done... and then do it again.
i think maxon's ad999 delay uses 4 3208s....
Quote from: Yuan Hanits possible, but having 4 more trimpots will make calibrating it tough !
thanks for your help man !!!
do you know where can I get a circuit board for the 4x 3208s ?
is it that simple ? just 2 more 3208 , nothing more ?
sorry, I'm not a technician......
thanks again !!
