DIY Stompboxes => Building your own stompbox => Topic started by: Prive on August 06, 2004, 08:33:04 PM
Title: Trinegistor working!!!!!!!!!!!!!
Post by: Prive on August 06, 2004, 08:33:04 PM
Yes yes an 3 times yes!!!!!!!!!!!!!!!!
I recieved some 2n2222 and after some months i give it a try again.
Yes it works right but how Zvex says 12V
Thanks Moosapotamus!!!!!!!!!!!!!!!!!!!!!!!!!!!
Saludos, Marcelo.
Post by: zachary vex on August 06, 2004, 09:34:19 PM
negistors can be fussy down around 9 volts.  they might work, but often have trouble.  i use a negistor in my nano head as the basis for a VCO/regulator in the high-voltage switching supply, and the input voltage is 12VDC for that one.
Post by: moosapotamus on August 07, 2004, 07:53:53 PM
Right on, Marcelo!
Very glad to hear you got some good stuff going on. Curious, did you make it with any changes to this circuit... http://www.moosapotamus.com/tri-negistor/TriNegSchematic.gif? I know that folks have gotten mixed results using the negistor as a sound/noise generator, particularly with putting three of them in series as in the tri-negistor. Good on you, man!!!
Cheers!
~ Charlie
Post by: Prive on August 12, 2004, 06:23:50 PM
The schem is the same, but i use 100 ohms against 100K and i think i'll change the pots to 10 or 20K cause only works in the lower R settings.
I made some changes in the caps value and i try one of your ideas, i use a momentary switch in series with a .01 cap from the second stage emitter to the first stage base, some kind of feedback, interesante!!!!!!
Completly another animal with 9V, maybe i'll use a switch between 9 and 12.
Saludos, Marcelo.
Post by: moosapotamus on August 13, 2004, 03:31:48 PM
Quote from: PriveCompletly another animal with 9V, maybe i'll use a switch between 9 and 12.
Cool, that's interesting. A sag pot to adjust the voltage might be worth a try, too.
~ Charlie
Post by: Paul Perry (Frostwave) on August 13, 2004, 07:17:11 PM
It should be possible to make a trinegistor style noisebox using 555s, since they are both relaxation oscillators.
Post by: troubledtom on August 13, 2004, 07:41:35 PM
Quote from: Paul Perry (Frostwave)It should be possible to make a trinegistor style noisebox using 555s, since they are both relaxation oscillators.
mooseman did it w/o the 555, i own it, he gave it to me. i luv it!!!!!
        peace,
            - tom
Post by: moosapotamus on August 13, 2004, 10:27:56 PM
hey tt... you rock! 8)
I am totally going to build that infinitephase. It's only, like, one of a dozen or so different projecets I've got going on at the same time right now, but it's right up there near the top! :wink:
Hope all is going well on your end.
~ Charlie
