DIY Stompboxes => Building your own stompbox => Topic started by: jimbob on August 07, 2004, 01:05:27 AM
Title: Re-built the amz mosfet boost
Post by: jimbob on August 07, 2004, 01:05:27 AM
I re built this thing--turns out the 1st time i did it it boosted a little and was decent--this time i took my time and WOW its a nice little booster..clean and sounds good w my amp--I didnt think there were any out there that would sound decent w my set up.. I think ill build a treble boost and see how that sounds..
Title: .
Post by: petemoore on August 07, 2004, 10:54:50 AM
Yupp, ain't that a kicker>>!!!
Post by: travissk on August 07, 2004, 02:10:26 PM
It's a great booster. Many commercial boutique pedals use that one or a derivative. I have one at the start of my chain and love it, thinking of building a second to place at some other part of the signal chain, i.e. before overdrive or distortion.
Post by: jimbob on August 07, 2004, 02:21:00 PM
how hard would it be to built 2 of these and connect them inside a board and use a switch between the 2--1 for the 1 boost and a 2nd switch to add more boost to the 1st?
Title: .
Post by: petemoore on August 07, 2004, 02:55:15 PM
Here's suggester:
 Have a DPDT  bypass the whole affair [two Mosfet boosts, 1rst one on when the 'box' is on], the second MB having a second bypass DPDT.
 So the first sw would bypass the box, the second would in/out the 2nd Mosfet boost.
 Use of 3PDT makes easy indicator for bypass's.
Post by: Phorhas on August 07, 2004, 03:22:24 PM
Truely an awsome sounding pedal... drives my amp wild :)
Jack is an artist.
Post by: RDV on August 07, 2004, 03:48:15 PM
Quote from: jimbobhow hard would it be to built 2 of these and connect them inside a board and use a switch between the 2--1 for the 1 boost and a 2nd switch to add more boost to the 1st?
Try this.
(http://img.photobucket.com/albums/v165/rickydon/Two_in_1_wiring.gif)
RDV
Post by: jimbob on August 07, 2004, 05:42:00 PM
Awsome RDV! Thats just what i was looking for!
thnks all
jim
Post by: jimbob on August 07, 2004, 05:47:55 PM
I was just thinking--could you do this with just 1 power source (where 1 turns off and you turn the other on and the other effect uses that other power source.--ya know 1 dc jack instead of 2? Or would that mean you could never use the 2 at the same time?
Post by: RDV on August 08, 2004, 03:14:23 AM
Yes, have another look at my little re-re-drawing. This is how I do it, I'd done the other drawing in a hurry.
RDV
Post by: jimbob on August 08, 2004, 03:12:45 PM
Very Very Cool!!
thanks
jim
