DIY Stompboxes => Building your own stompbox => Topic started by: John Egerton on August 20, 2004, 12:35:20 PM
Title: A circuit to aid my amps's effects loop?
Post by: John Egerton on August 20, 2004, 12:35:20 PM
Hey guys,
I was wondering if you could help me with this problem...
I own a marshall mode 4 and i use it in conjunction with the effects loop which contains various pedals that are both true bypass and not.
I also use a fuzz factory that goes directly from my guitar to my amp...
On the mode 4 is an effects loop level knob that will increase/decrease the volume of the pedals in the effects loop to their relevant volumes...
I like the effects in the loop to be at the level they would if they were in the primary chain which invlolves turning th knob to max.
However when I increase the effects loop level, my fuzz factory looses both a little volume and tone...
I was wondering if there was something that I could place in my effects loop to prevent it from doing this?
John
Post by: niftydog on August 26, 2004, 12:35:09 AM
build a modified boost pedal, ie; make an active volume control with some gain. Then, use that to boost the level coming out of the effects loop.
