Hi everyone,
Is there any reason against using Darlington transistors in boosts or overdrives? Like noise or interference?
Thanxs,
Alex
eh...some are noisey. Socket and try. I played around with them in a multiface, and they sounded good for some stuff, but it was _too much_ gain. Like...it was a fizzy, high trebleish sound.
But hear it for yourself.
The thing about Darlingtons is that they are essentially two transistors in one. They are configured in such a way that the darlington's Beta value can be found by multiplying the individual Beta values of each transistor...
Beta * Base Current = Collector Current. If a typical BJT has Beta of 100, the Base Current times 100 will calculate the collector current at that moment in time.
If we use 2 of these BJTs to construct the Darlington, it's Beta value would be 10,000, which isn't at all unrealistic. Base Current times 10,000 is, of course, a much higher collector current, and would probably reach the saturation limit set by the collector resistor.
Essentially, this means that the Darlington is prone to clipping much harder than a single BJT.
I think that for most circuits, you can swap a Darlington in where a BJT was and it will work to some extent, never tried it tho...
Take care!
