DIY Stompboxes => Building your own stompbox => Topic started by: Paul Marossy on August 20, 2004, 09:06:05 PM
Title: Shaka Tube's Insides - L@@K here... (progress report)
Post by: Paul Marossy on August 20, 2004, 09:06:05 PM
Aron-
I'm thinking about trying to move my Shaka Tube's guts into a Hammond 1590BB enclosure. I remember that you had a picture of the inside of yours in that type of enclosure. I think that was a couple of years ago at the really old forum. Do you know where I can find that picture so I can get an idea of how the layout should be?
Post by: Hal on August 20, 2004, 09:16:55 PM
is this the picture you're talking about?
(http://www.diystompboxes.com/pedals/photos/shakaguts.JPG)
Post by: aron on August 20, 2004, 10:22:17 PM
Wow. Pictures live forever! Thanks for posting it!
Post by: Hal on August 20, 2004, 11:05:16 PM
yea...searched the forums :-D
Post by: aron on August 21, 2004, 12:43:28 AM
I remember I was happy because I found those cheap clamps to use to hold the tube inside the box. It worked.
Post by: Paul Marossy on August 21, 2004, 01:01:49 AM
Thanks, that's the one I was thinking of.  8)
Title: .
Post by: petemoore on August 21, 2004, 02:36:03 AM
My tube socket had a hole in the middle of it I used for mounting it to perf...I just used a sleeve [like a ball point pen...cut real straight] to keep the lugs up where I could get 'em, and a nut and bolt....bolt through tube socket and 'jack up sleeve' nut and washer....simple, easy and uses common stuff...that clamp does look good...solid...
 Just a possible alternative way to do it,...
Post by: mugan on August 21, 2004, 08:17:33 AM
Did anyone design a pcb for this?
Post by: Paul Marossy on August 21, 2004, 11:02:33 AM
Look here:
http://www.diystompboxes.com/pedals/pcb/shakatube/
Post by: Thomas P. on August 21, 2004, 11:11:06 AM
I packed my Shakatube inside of a 1590BB. With the layouts posted it should be possible.
Hey Paul I send you a picture of mine...
Post by: Paul Marossy on August 21, 2004, 11:19:58 AM
tomboy-
That would be great! I am having some trouble figuring out how to get all this stuff in that size enclosure with the hardware layout that I want. It's the height that is giving me the problems. My current enclosure is slightly larger than a Hammond 1590BB. I may design a PCB layout to acheieve what I want. Then again, the one I have works fine already...
EDIT:
These graphics should give you an idea of what I want. I don't know that it can be laid out this way in a Hammond 1590BB...
http://www.diyguitarist.com/Images/ShTubeGraphix.bmp
Post by: Thomas P. on August 21, 2004, 12:35:34 PM
I didn't find the inside picture but I sent you another one where you can see how I managed the tube and the pots.
inside pcture follows soon...
Post by: Paul Marossy on August 25, 2004, 01:00:54 PM
OK, I think I have it figured out. I have done a couple of new PCBs designed around a Hammond 1590BB enclosure, and figured out a layout that should work with how how I want the hardware and graphics to be set up on the box.
Check it out:
http://www.diyguitarist.com/PDF_Files/ShTube1590BB-PCB.pdf
http://www.diyguitarist.com/PDF_Files/ShTube1590BB-Layout.pdf
I figure that I'll do some kind of sheet metal bracket to hold the tube socket using the bypass switch to hold it in place.
Post by: mugan on August 25, 2004, 01:12:33 PM
why don't u turn the tube upside down? u'll get shorter wires!
Post by: Paul Marossy on August 25, 2004, 01:13:58 PM
Well, then I couldn't get the tube out...
The length of wires in my current build are actually longer than what I would have in this one. It hasn't been a problem for me.
Post by: mugan on August 25, 2004, 01:23:29 PM
:D  i didn't think about a possible tube removal
Post by: aron on August 25, 2004, 03:53:07 PM
WOW, very nice!!!!!
Thanks!!!!!
Post by: Paul Marossy on August 25, 2004, 04:25:19 PM
Glad you like it.  8)
I'm going to get started on it tonight...
I will get the PDFs so that they print the correct size in the next few days. I need to verify that everything works before I go sharing them with the world at large. If anyone sees any mistakes, please let me know ASAP! Thanks.  :wink:
Post by: Paul Marossy on August 26, 2004, 01:33:55 AM
Well, I have the two PCBs etched now and half-populated tonight. I'll probably be finished with it by Saturday afternoon. Hopefully, everything goes smooth...
Post by: Paul Marossy on August 26, 2004, 10:21:08 AM
Got the PCBs populated now, and I made a bracket out of some sheet aluminum to hold the tube socket. Next, I'm going to drill the enclosure. So far, everything is working out as planned. I'll post a couple of pictures of my progress soon - probably this evening.
Post by: Paul Marossy on August 27, 2004, 01:43:16 AM
OK, here's a few pics. So far, everything is going as planned. I'll be soldering the interconnective wiring tomorrow night.
(http://www.diyguitarist.com/Images/ST1590BB-Bracket.JPG)
This is the bracket I made for holding the tube socket. I drilled the holes after I bent it up. Kind of a pain doing it that way, but it worked out OK. I used a paper mock up to figure out what shape it should be and stuff.
(http://www.diyguitarist.com/Images/ST1590BB-Bracket1.JPG)
Here is a view showing how the bracket will be held in place.
(http://www.diyguitarist.com/Images/ST1590BB-Interior.JPG)
Here is a test run to see how everything fits inside. To the left is my prototype AuotCAD drawing. The only thing I don't have worked yet out is where to put the AC jack, but I think I have a good spot for it...
Post by: Lonestarjohnny on August 27, 2004, 01:52:27 AM
Nice lookin build Paul, you gonna use shielded cable for your signal path run's ?
Johnny
Post by: Paul Marossy on August 27, 2004, 10:31:31 AM
Yep, I'll use shielded wire. I used shielded wire on my other Shaka Tube build, which I called the "Bulldog", and this layout basically follows the layout of the Bulldog, except for the tube is in a different location. So, based on the success of the Bulldog, I anticipate this one ought to work OK as well. I just wanted to get this circuit in a more compact enclosure, and I can't seem to walk away from a technical challenge like this...  :wink:
