Can anyone explain what that is?
Thanks,
Tony
I have no idea. What context did it come up in?
Sinewave oscillators usually have a loop with a gain control in the loop that adjusts the gain to stay just on the edge of oscillation, to avoid overdriving & keep the output waveform pure. Works down to thousnadths of a % distortion, too!!
all oscillators could be described as "gain driven". Google "Barkhausen criteria " for more info.
Theoretically, you need unity gain and feedback to make an oscillator.
In practise, the gain varies around unity at all times. Positive gain builds up the oscillations, but if let run wild you'll end up with clipping, so when the oscillations get to a certain point, negative gain is needed to keep it under control, then you go to low and need positive gain again... etc etc. ad infinitum.
Maybe the idea is that you can turn off the oscillations or cause the oscillator to clip by affecting the gain of the circuit. :?:
I'm guessing you got that off of the parallel universe schematic... what I meant was that the frequency was controlled by the gain. Man, I wrote that a long time ago... it was me trying to explain something I didn't quite understand.
-Colin
Quote from: anonymousexperimentalistI'm guessing you got that off of the parallel universe schematic... what I meant was that the frequency was controlled by the gain. Man, I wrote that a long time ago... it was me trying to explain something I didn't quite understand.
-Colin
Yes, It looks very interesting. What does it sound like?
Thanks for explaining the term.
Tony
Quote from: TonyQuote from: anonymousexperimentalistI'm guessing you got that off of the parallel universe schematic... what I meant was that the frequency was controlled by the gain. Man, I wrote that a long time ago... it was me trying to explain something I didn't quite understand.
-Colin
Tony
It's hardly a term though, so don't quote me ;)
Go to http://www.nseffects.com. There are a few clips there.
-Colin
What is the source of the term?
I haven't heard of it but I could extrapolate like others have.
People make up terms all the time - some stuff you don't have to worry about.
Quote from: BoofheadWhat is the source of the term?
The source is basically that the frequency is determined by the gain-gain driven. Envelope controlled frequency oscillator would be a better way to say it.
-Colin
QuoteThe source is basically that the frequency is determined by the gain-gain driven. Enve
I meant where did the original poster find the term written down. People invent terms all the time - there's a difference between common technical terms and things people make-up on an adhoc basis. I wouldn't be too worried about the latter.
He got it off of Colin's Parallel Universe schematic:
http://www.experimentalistsanonymous.com/diy/Schematics/Parallel%20Universe%20Schematic.gif
-Travis
Yes, I got it off of his site. Very interesting design and great sound. I can hear the oscillation going on, almost like a ring mod.
Thanks,
Tony
