DIY Stompboxes => Building your own stompbox => Topic started by: mat on September 23, 2004, 06:30:48 PM
Title: SOT: simpleish micpreamp
Post by: mat on September 23, 2004, 06:30:48 PM
I'm very close to buy a micpreamp for recording my amp into the PC.
But i would first like to know if anyone knows a simple chematic for a circuit that would boost the mic and spit out line level stuff. It doesnt have to have tone adjustment, just one volume knob. And if possible, two channels to be able to record two microphones simultaneously.
Would it be possible to use it also to go thru pedals and then in to the preamp and to PC ?
I'm thinking something like this:
http://www.netzmarkt.de/thomann/thoiw3_art_tube_mp_studio_prodinfo.html
or like this:
http://www.netzmarkt.de/thomann/thoiw3_midiman_dmp_3_prodinfo.html
cheers,
mat
Post by: Aharon on September 23, 2004, 06:38:17 PM
AMZ has one  but for the money you can't beat the ART Mic Pre.
Aharon
Post by: Hal on September 23, 2004, 06:39:25 PM
i would say make a simple op-amp preamp...use a 100k pot at the output to set volume, and fix gain at something like 4...maybe a little more.
if you're running after effects you probably don't even need that
Post by: mat on September 23, 2004, 06:46:45 PM
Hi!
Thanks for the super fast answer  :D
Do You have the ART micpreamp ? Is it good quality ?
Thanks,
mat
Quote from: AharonAMZ has one  but for the money you can't beat the ART Mic Pre.
Aharon
Post by: mat on September 23, 2004, 07:08:20 PM
Hi!
And thanks also for the super fast answer  :D
That is exactly what i meant. But the problem is i dont know how to do it  :evil:
I have few TL072 IC's.
The input would go to pin... ?
The output would go from pin... ?
The ground would be connected to the pin... ?
The volumepot would be the last component and would bleed to ground.. ?
Any resistors, caps in where..?
And making two of these in one box to use with two mics  :P
The fixing gain at 4 is too something that i do not understand.. :roll:
Could someone complite the lines and maybe components i'm missing here  :oops:
(http://tinypic.com/a08qp)
I have to apologise but this is just how novice i'm today with these things  :oops:  :oops:  :oops:
mat
Quote from: Hali would say make a simple op-amp preamp...use a 100k pot at the output to set volume, and fix gain at something like 4...maybe a little more.
Title: MXR
Post by: petemoore on September 23, 2004, 09:31:21 PM
MXR Micro Amp...Great Build for guitar, For use of a Dual OA, tho you'd only use one half of it. Pretty clean...I use a 5534... cleaner than a TL I think. Great Opamp booster.
 If you have a mosfet like 2n7000 and a protection diode, the Mosfet Boost is a Very Clean Booster with alot of gain.
 What the application is, is improtant though, often it's not the lack of input signal that makes a mic behave a 'ertain' way...feedback for instance.. you may not notice any gains in volume before feedback...depending...
Title: Re: MXR
Post by: mat on September 24, 2004, 12:47:46 PM
Would the MXR Micro Amps output feed the PC's line in properly when having a Shure SM57 in the input of the MXR ?
mat
Quote from: petemooreMXR Micro Amp...Great Build for guitar, For use of a Dual OA, tho you'd only use one half of it. Pretty clean...I use a 5534... cleaner than a TL I think. Great Opamp booster.
Post by: RDV on September 24, 2004, 05:33:35 PM
(http://img.photobucket.com/albums/v165/rickydon/SuperSimplePre-Amp.gif)
Just leave out the 3-band.
RDV
Title: Re: MXR
Post by: Hal on September 24, 2004, 05:43:56 PM
should be good....works well with my guitar...
http://www.crazychucks.com/guitar/PREAMPS.GIF
I made the op-amp one, with the gain of 2, in my guitar, with a 741.  Sounds good.  Its fairly transparent, even with a terrible IC.  :-D
Quote from: matWould the MXR Micro Amps output feed the PC's line in properly when having a Shure SM57 in the input of the MXR ?
mat
Post by: lovekraft0 on September 25, 2004, 12:22:28 AM
If you're looking for something studio quality, take a look at this:
DIY JFET Mic Pre (http://members.cox.net/soma/hamptone.jpg)
Board layouts are available at The Lab (http://www.prodigy-pro.com/forum/viewforum.php?f=2) (search for hamptone)
Post by: mat on September 26, 2004, 04:45:19 PM
Hi lovekraft0  :D
This Hamptone looks very cool ! I read quite a bit of it from 'The Lab' (cool forum). I'm definitely going to build this one, maybe several of them for different purposes. Thanks a lot for this option !!
RDV!
Thank You for the schematic. Should i leave on one 1uF cap between the IC's when i remove the tone stage ?
Hal!
I think I'll build first the same as You did. Because it is simpliest of the suggestions - i'll propably manage to finish that one  :roll:
And thanks also to petemoore, what a forum, what a people  :o  :o  :o  :o  :o
cheers,
mat
Post by: Aharon on September 26, 2004, 05:20:28 PM
Quote from: matHi!
Thanks,
mat
Aharon
Yes I have one and it's good quality and priced right.
Aharon
