DIY Stompboxes => Building your own stompbox => Topic started by: Leprecon on September 07, 2003, 03:25:40 AM
Title: modifying a Morley Power Wah, like a bad horsie
Post by: Leprecon on September 07, 2003, 03:25:40 AM
http://www.morleypedals.com/pwo.pdf
http://www.morleypedals.com/vai-1.pdf
Hi, could someone help me? I posted a topic before on how to med a crybaby, so that it would function as a bad horsie... Now I've bought a Power Wah, and I'm thinking of modding it...
The power Wah also work with an electro optical switching, and has got a true bypass... And so, the only thing that should be changed, is the fact that it has to be engaged when you step on it, and turned off when you step of it...
The schematic for the Power wah and the bad horsie are on top.
I'm really new at this, so please if you want to help me, give lots of details 'cause otherwise I'll probably nag your ears off with stupid questions.
Thanx
Post by: Jered on September 08, 2003, 01:21:04 AM
I know this isn't the answer you want to hear but, honestly, converting a power wah to a bad horsie is not a beginner project. Start small, work your eway up to it, before you know it you will be doing the mods yourself.
  Good luck,  Jered
Post by: Leprecon on September 08, 2003, 02:57:47 AM
Well, that wasn't exactly what I wanted to hear, but I appreciate the honesty... As a beginner I'm not familiar with what is difficult or what not so, now you've told me that this is to difficult, I'll try to find some other project, and then after I've aquired some experience I'll try to mod my Power wah...
Thanx
PS Any suggestions for a beginner, with what I could begin? I'm living in Belgium, so I don't know if everything from internet is availeble here, but I'll see...
