DIY Stompboxes => Building your own stompbox => Topic started by: CoolJohnny on October 19, 2005, 01:51:37 PM
Title: LPB-1 low output
Post by: CoolJohnny on October 19, 2005, 01:51:37 PM
love the transparency of this circuit but never figured out how to get more gain out of it. bare sound is just a hair above unity (where i like my pedals to start) but can't seem to get any more grit. i've gone through so many boosters in the last couple of years...always on the quest for the best, so i thought i'd revisit this one...ideas? experiences?
Title: Re: LPB-1 low output
Post by: GVC on October 19, 2005, 01:56:07 PM
Which tranny did you use?
Post by: petemoore on October 19, 2005, 02:27:56 PM
  You've done enough booster it sounds like to compare this one to.
  Is it working?
Post by: vanhansen on October 19, 2005, 05:45:50 PM
Sounds either mis-biased or the tranny is in backwords.  I've breadboarded the LPB-1 a number of times and every time it has a very serious boost.
Post by: Xavier on October 19, 2005, 06:05:21 PM
If you used a 2N5088 transistor as I did, try a 2N5089. I did this because of the very same reason. The change in output is very noticeable.
Post by: phaeton on October 20, 2005, 01:27:55 AM
I used a BC549 i believe, and to good result.
However, if your breadboarded ones are different than your soldered ones, then something is wrong.  Overcooking the transistor, perhaps?
