DIY Stompboxes => Building your own stompbox => Topic started by: mgrEIGHT on October 20, 2005, 04:19:23 PM
Title: Multimeter question
Post by: mgrEIGHT on October 20, 2005, 04:19:23 PM
I realized i need a multimeter if i want to continue this fine hobby of making diy effects(and i do). I was looking around on the radioshack site and the prices seem to be determined by range. What do they mean by range and how much range do i need for just trouble shooting guitar effects and maybe testing pickup outputs?
Title: Re: Multimeter question
Post by: gaussmarkov on October 20, 2005, 05:12:31 PM
range refers to what values can be measured.  for instance, my dmm only measures resistors up to 2M.  so i cannot check a 2.2M resistor, except by putting in parallel with something smaller than 2M and doing some arithmetic.  :)  there is a range for each thing measured (dc, resistance, ...).
there are probably as many opinions about this as there are forum members.  ;)  i am a beginner, too.  i bought the $10 radio shack dmm and it has served me well.  but if you are going to stick with this hobby and do more ambitious things than beginners can do, i suggest that you pony up for something that can measure capacitors and has a greater range.
Post by: KORGULL on October 20, 2005, 06:17:49 PM
I have a Radio Shack meter that is pretty nice - says on the back: cat# 22-811.
I got it on sale for around $35-$40. It can measure caps (up to a certain value), has audible continuity test, and has an auto-range feature - so you can still get an accurate reading - even if you neglect to set it to the proper range. It also has a diode check function.
Probably the best thing it does is to automatically shut itself off if you leave it on - which I do constantly.
...This is the one:
http://www.radioshack.com/product.asp?cookie%5Ftest=1&catalog_name=CTLG&category_name=CTLG_011_008_002_000&product_id=22-811 (http://www.radioshack.com/product.asp?cookie%5Ftest=1&catalog_name=CTLG&category_name=CTLG_011_008_002_000&product_id=22-811)
Post by: Paul Perry (Frostwave) on October 20, 2005, 10:03:25 PM
The main price jump is when you get 4 or 5 or more!!!!!!! digits.
For normal stompbox work, three is plenty, honest.
I've had to stump up for a high precision $$$ one for synthesiser work, but for diy stompbox $50 (or less, use the search function to see how to get a 'free' meter by buying $50 worth of parts from some shops). The one thing i woulod wnt in a meter, is to be sure it has the 'continuity beep' function. Because most faults (for everyone, and especially me :icon_redface: ) are shorts, and you want to be able to hear the beep, without having to look. and a transiistor gain (Hfe) option is useful, if only to work out which way the transistor leads go.
