DIY Stompboxes => Building your own stompbox => Topic started by: ANDYEFFECT on May 02, 2006, 09:16:16 AM
Title: How to have more clarity and less medium in TS-808?
Post by: ANDYEFFECT on May 02, 2006, 09:16:16 AM
I already tried several modifications that didn't give effect.
how do I do to have more clarity and less medium in TS-808?
I want him to work like LTD, without altering the emblem of the instrument a lot.
Thankful.
Title: Re: How to have more clarity and less medium in TS-808?
Post by: petemoore on May 02, 2006, 09:25:11 AM
  I 'see' it as you want more sizzle on the very treble, and same or a bit less mids?
  A resistor with a paralleled cap across it, in the signal path is one thing I might try. BSIAB does that, as do other circuits, check around and look for an R with paralleled C...The BSIAB I think uses a 470k / 470pf...kinda big...maybe take the 0's off and have 47k / 47pf...
  Just ramble/typing here...but that's one approach to 'leak a little treble across' and cut everything else a bit [too much cut?]...I think...
Post by: Mark Hammer on May 02, 2006, 09:25:51 AM
Build a different pedal.  The question you ask is like asking "How do I turn my Volkswagon convertible into a pickup truck?"  or "How do I turn my girlfriend into a guy so we can go to sporting events together?".  You CAN do it, but it is probably better to just let the 808 be itself and use a different circuit to do what you want.
Post by: ANDYEFFECT on May 02, 2006, 09:32:01 AM
Quote from: petemoore on May 02, 2006, 09:25:11 AM
yes I want less medium and more transparency, non treble.
Post by: goosonique on May 02, 2006, 09:34:50 AM
...the .22uf tone cap c9 and cap to ground c5 after first op-amp stage reduced  . ... go with the Boss SD value. ;)
check here : http://www.freeinfosociety.com/electronics/schemview.php?id=1136
Post by: petemoore on May 02, 2006, 09:48:45 AM
  I bought me a new 20 dolla EQ pedal, works great for dialing in pretty precisely what frequencies I want...to feed the pedal / to accentuate/attenuate after the pedal.
Post by: markm on May 02, 2006, 09:51:27 AM
A little off topic maybe but, in relation to what Mark says,
how about the OD-250 circuit.
Has great sound, is a simple build and may be more what you want.
I love the OD-250 but then again, I have NEVER had any attraction to the 808.
I'm just not an Tubescreamer type of guy.
  MarkM
Post by: ANDYEFFECT on May 02, 2006, 03:34:04 PM
if I increase 51pf for 120pf does it help to reduce highs?
if I remove tone control does it also improve answer for a more natural overdrive?
thankful.
Post by: Mark Hammer on May 02, 2006, 04:08:41 PM
Quote from: ANDYEFFECT on May 02, 2006, 03:34:04 PM
With C=51pf, highs are rolled off around 5.6khz in that stage at maximum gain.  With C=120pf, they are rolled off around 2.4khz in the same stage.
thankful.
It does not produce a more "natural overdrive" but with a 120pf cap in the first stage the tone control will be almost useless since there will be much less treble for it to control.  A bit like having a nice hairbrush...for a bald man.
If you don't need that treble, or need the tone control, you can always use the extra op-amp for a volume booster.  Replace the 1k feedback resistor with a 10k resistor.  Replace the .22uf tantalum tone cap with a 1uf unit.  Replace the 220R resistor with 2k2.  Cut the connection between the 20k tone pot and the + input pin of the second op-amp stage.  That will give you an extra boost of up to around x5.5 so that you can set the pedal for low drive but still get a big boost to push the amp.
Post by: twabelljr on May 02, 2006, 07:13:20 PM
Frank Clarke's Tube Screamer "General Hotrodding": (good stuff!)
http://web.archive.org/web/20010629003426/members.home.net/fclarke/fx/Distortion-17.htm (http://web.archive.org/web/20010629003426/members.home.net/fclarke/fx/Distortion-17.htm)
Post by: ANDYEFFECT on May 03, 2006, 06:45:30 AM
Quote from: twabelljr on May 02, 2006, 07:13:20 PM
very good, it was worth friend.
Post by: Roobin on May 03, 2006, 02:30:19 PM
I think I remember reading something on Muzique.com about making the TS 'Fat'
Post by: ANDYEFFECT on May 04, 2006, 08:15:04 AM
yesterday I did make some tests, and do lower 1k of
the 0.22 and did sound sound have more clarity (am I correct?), was the
sound very similar with Barber, what does influence the 1k/220n?
