DIY Stompboxes => Building your own stompbox => Topic started by: skiraly017 on May 02, 2006, 10:58:33 AM
Title: The "how and why" behind pot and resistor choice for a mix circuit?
Post by: skiraly017 on May 02, 2006, 10:58:33 AM
I finally figured out how to add a mix pot to my Small Clone build but what I do not understand is how and why it works. The mix resistors are the 20k and 22k. I replacedthe 22k with a 50k pot and a 18k resistor is series. What's the math behind that combination?  I'm probably overlooking something obvious.
The reason for this question is because I'd like to add a mix pot to a phaser build. I've located the resistors that control the mix but need to figure out what pot/resisitor combination to replace one of them with.
Any insight would be greatly appreciated.
Title: Re: The "how and why" behind pot and resistor choice for a mix circuit?
Post by: DuncanM on May 02, 2006, 11:43:44 AM
If I understand correctly, it seems that :
The 22k determines the level of the direct signal, the 20k determines the level of the effect signal.
You have replaced the 22k with 18k and a 50k pot so.......
18k with the pot at zero will give slightly more (1.7dB) direct level than stock and turning the pot up to max will give you (50+18) 68k causing the direct signal will be reduced by -9.8dB [22/68 expressed in decibels]
So by changing the direct level while the effect level remains the same you are able to vary the mix.....
A bigger pot would remove more direct signal and you'd have a vibrato option.......
Post by: skiraly017 on May 02, 2006, 12:53:34 PM
So if I understand this correctly and the resistor I'm looking to replace in the phaser is a 150k, it's just a matter of finding a pot and resistor combination that offers more direct signal at zero and less direct signal at max?
Post by: DuncanM on May 02, 2006, 02:07:48 PM
I'd have to look at a schematic...... but essentially yes - something like a 120k resistor and a 1M pot. I'm not sure what it would sound like though...
