DIY Stompboxes => Building your own stompbox => Topic started by: modsquad on January 15, 2007, 06:56:38 PM
Title: Pulldown Resistor?
Post by: modsquad on January 15, 2007, 06:56:38 PM
My understanding is that a pulldown resistor can be placed before the first cap in the circuit and ground and/or after the last cap and ground in the circuit.   Does that mean that I could conceivably solder them to the lugs on the input and output jacks?
Title: Re: Pulldown Resistor?
Post by: The Tone God on January 15, 2007, 07:02:08 PM
Not if you are going to use a bypass switch as the resistors have to be connected to the caps even when bypassed.
Andrew
Post by: MartyMart on January 15, 2007, 07:22:05 PM
That's how they wire them in amps, as there's no "bypass" on an amp, thay can be on the jack socket :D
MM.
Post by: Papa_lazerous on January 15, 2007, 07:30:31 PM
Quote from: MartyMart on January 15, 2007, 07:22:05 PM
MM.
This is true, but on a stomp box if you want TB then you dont want the pull down resistors there as you will get "tone sucking" put the resistors on board simple ;)
Post by: The Tone God on January 15, 2007, 07:49:32 PM
Quote from: Papa_lazerous on January 15, 2007, 07:30:31 PM
Tone sucking is one issue. The bigger issue is there will no longer be pop reduction which is the main reason why most effects have pulldown resistors. The resistor has to be connected to the cap when the effect is bypassed to drain away any residual DC. If you switch the resistor with the effect bypass switch the resistor will not have enough time to drain away the DC thus a potential for popping.
Andrew
Post by: Papa_lazerous on January 15, 2007, 08:25:18 PM
That would alo be a very good comment ;)
Post by: modsquad on January 16, 2007, 12:35:24 PM
So then I just place them before the first cap after the input jack on the board and after the last cap before the output to the jack.
Post by: zjokka on January 16, 2007, 03:29:54 PM
on a fat boostered I gladly included it as it was standard on the layout
when installing the led I used a super bright red led, now the box is still popping...
I didn't measure that led yet, but is there a way of knowing the value of the PD resistor without testing?
Is it the 'super' that makes for the popping despite the 1M5 pulldown
sorry to squeeze in, but not so completely off-topic
zj
Post by: Seljer on January 16, 2007, 03:48:19 PM
Quote from: modsquad on January 16, 2007, 12:35:24 PM
theres that bypass switch between the capacitor and the jacks, which is the source of the popping you are trying to prevent with pulldown resistors
and like mentioned, you have to place them between the input/output cap and the switch
(sometimes, if you've got a volume control at the end of a circuit theres no need for the output one)
Post by: ubersam on January 16, 2007, 04:21:07 PM
Quote from: zjokka on January 16, 2007, 03:29:54 PM
It sounds like you are experiencing LED pop, in which case, you might want to check this out: http://www.muzique.com/lab/led.htm (http://www.muzique.com/lab/led.htm). It is like decoupling the LED circuit via a BFC. I add this in if I get popping even a pulldown resistors on the input stage.
Post by: zjokka on January 18, 2007, 07:14:23 AM
Quote from: ubersam on January 16, 2007, 04:21:07 PM
thanks man! was just planning on increasing the pulldown resistor.
