DIY Stompboxes => Building your own stompbox => Topic started by: southtown on February 03, 2007, 07:22:35 PM
Title: if my battery heats up....
Post by: southtown on February 03, 2007, 07:22:35 PM
and my contnuity tester beeps when i put the leads on the empty battery clip, it means what ?
Title: Re: if my battery heats up....
Post by: zyxwyvu on February 03, 2007, 07:33:31 PM
That means you have a short somewhere between power and ground. You should check for extra solder joints or other places they could connect.
Post by: petemoore on February 03, 2007, 08:37:42 PM
 Reverse the order, postpone the second task...
  Test for non-continuity between V+/V-, don't connect PS...eliminate shorts before supplying power.
Post by: southtown on February 04, 2007, 12:46:05 PM
i got it, took me about 2 hours to find a little piece of solder has bridged 2 strips
