Hi... sorry if I should have been able to find the answer to this on my own... but if I use the E-Switch 1XJN002UEE from Smallbear,
http://www.smallbearelec.com/Detail.bok?no=33
does this switch actually operate in a push-on, push-off fashion like a stompswitch? or is it momentary contacts & needs some sort of logic-switching?
thanks!
Kyle
Took me a bit to find - (e-switch's website is not giving me datasheets for some reason - I found the same switch/manufacturer part number in the Digikey catalog) but yes, it is latching.
Quote from: KWilcox on February 05, 2007, 05:27:46 PM
Yes. If you already have worked out exactly How you want to build it into you design, fine. If not, my design for a Shell might be useful:
http://www.smallbearelec.com/HowTos/Shell/Shell.html
One caveat, though: The Switch Actuator SKU 0212 is out of stock and won't be in till my next boat gets here from Taiwan in early March.
Regards
SD
