DIY Stompboxes => Building your own stompbox => Topic started by: gez on May 09, 2008, 03:25:13 PM
Title: Drilling Steel?
Post by: gez on May 09, 2008, 03:25:13 PM
How the hell do you drill sheet steel??
I drilled some today (I recut the bracket of a top-snare mechanism to improve the sizzle).  Only thin stuff (0.7mm or 0.5mm, can't remember which), but my drill bits, all for metal, barely made a dent in it with my trusty power drill!  After a number of minutes of drilling the dent was deep enough to have thinned the metal enough to drive a nail through, and then it was easier to drill through it.  Once the hole was opened up enough to get a varibit in there, it was plain sailing; but how to drill the initial hole?  The bits I was using (both now blunted) were 3mm.  Is (slightly) smaller better, or should I have used special bits?
How do the big boys do this?  Punch holes rather than drillng? Or do I need one of these:
(http://farm1.static.flickr.com/194/474171351_36368ea9f9.jpg?v=0)
Managed to get the job done in the end, but what a bleedin' palava...
Title: Re: Drilling Steel?
Post by: OscarMeat on May 09, 2008, 03:49:16 PM
Seems strange...was the metal just plain steel or maybe "rust-free" stuff? That won't budge with a normal drill bit.
I would buy one or two special bits for steel sheet. I have couple of bits made of volfram, so they cut easily thru even 1.8mm sheet.
I've made a few stomboxes of 1.25mm steel sheet, bent and drilled, then enameled. Makes a tough little box :D
Post by: Nasse on May 09, 2008, 03:49:45 PM
Dunno if it was your problem but big boys told me drilling certain types of stainless steel is very troublesome or almost impossible, and I think they did not lie to me. We had a very good drill press at the workshop at those days and they told me to use cooling/lubricating liquid and not burn the drill bit by doing it too fast or with too much pressure. Those thick things were zinc-plated Fe 37 B and not stainless steel, but it needed a steady hand anyway. Talking about drill bits I bought a supercheap set for woodworking, and they were totally crap, not useful at all.
Post by: gez on May 09, 2008, 04:01:17 PM
Quote from: OscarMeat on May 09, 2008, 03:49:16 PM
Ah, that might be it.  It's 'mirrored stainless steel'.  I've widened holes in steel enclosures before, but never had to cut them from scratch.  I didn't think it was going to be that difficult!  Well, the upside is it's incredibly strong so I don't think I'll ever need to replace the bracket!
Post by: OscarMeat on May 09, 2008, 04:23:04 PM
yep, stainless steel  ::)  is hard stuff to drill. I've used laser cutting at my work if I needed more than one hole to a plate.
Post by: dschwartz on May 09, 2008, 04:54:59 PM
i ruined most of my drillbits drilling steel studs..
i used to make deep indentations on the surface with a hamer and one of those big nails for marking drill poins..if the drill didn´t cut in, i would deep the indentation more and more, till the bit passed thru
i remember the effort, brutality and danger that drilling those things are..i really don´t know how i still have my 10 fingers complete...
Post by: Mick Bailey on May 09, 2008, 04:56:01 PM
Mild steel drills easily, though thin sheet can grab as the drill breaks through. Clamp the work and back it up with a piece of timber, MDF, ply or chipboard to support both the work and the emerging drill.  A little lubricant helps, but isn't essential if you're only drilling a few holes and are using HSS bits.
Some materials are very prone to work hardening, especially if the drill skids or drilling pressure is too light to maintain an effective cutting action. Some stainless steels and certain bronzes can be quite difficult to drill because of this. I've recently done a job involving drilling hundreds of 3/8" holes in thin stainless sheet that required the bit to be resharpened every 5 holes and the swarf came off red hot.
You can buy special drills for difficult materials with different geometry, alloys and coatings - the reference is the 'Dormer Twistdrill Handbook' which goes into a lot of detail on the subject. I've always managed with standard HSS drills and have modified the cutting angles to improve drilling too-soft or too-tough materials with a great deal of success.
Post by: drewl on May 09, 2008, 10:51:19 PM
Get a turret press!
Bad memories from when I was running a machine shop......I was doing CAD and they needed someone to run it.
Damn, I could have run off enough amp chassis' and boxes to last me a lifetime If I'd only known :-\
Post by: The Iron Chef on May 10, 2008, 07:56:46 AM
Get a "split point " drill bit. (do an image search) This style needs much less pressure to start pulling a chip. Stays centered better too. Use a drill press if you can and be carefull.  The drill press is the most dangerous tool in the shop. imho
-Keith
Ah, make sure your drill spindle is not running in reverse. im not kidding.
Post by: gez on May 10, 2008, 09:05:46 AM
Quote from: drewl on May 09, 2008, 10:51:19 PM
Get a turret press!
Unfortunately they seem to be very expensive.  However, this punch looks like it should do the job:
http://www.toolsnstuff.co.uk/product_info.php?products_id=3774
As I said above, once I can make a hole big enough for the varibit it's all plain sailing so I think a punch would be the way to go.  Having said that, the job is done; but, because one of the holes ended up askew, the snare wires run at a slight angle.  Makes no difference to the performance of the drum - it now sounds incredibly good (huge improvement with the new fixing attachment) - but knowing that it's slightly askew is giving me sleepless nights ( :icon_lol:).  I might re-cut it (I still have spare sheet steel); if I do the above would be the cheap way to do it.  Unless it's a false economy?  Anyone used one?
Post by: 5thumbs on May 10, 2008, 09:10:53 AM
Quote from: Nasse on May 09, 2008, 03:49:45 PM
Nasse brings up a very good point about lubrication, drilling pressure and drill speed.  I've drilled a lot of holes of a wide variety of sizes in all sorts of steel when repairing farm equipment and other stuff.  I've found the speed guide inside the lid of my shop drill press to be very useful in determining a good speed for a given hole size on a given material.  Spinning the bit too fast with too much pressure burns up the drill bit, as well as can make the bit jump a lot and/or grab the work piece and bind up.  If the bit is working properly and properly lubricated, you don't need much pressure to maintain drilling progress.
Lubrication and patience are very important.  I use thread cutting oil, but I imagine plain old mineral oil in a pinpoint squirt bottle would be just fine.  I use a center punch to get a starting dimple.  If I'm drilling a larger diameter hole on a thick piece, I'll usually start the hole with a 1/8" bit and drill at least 1/4" into the work piece.  I apply a drop of lube to the starting dimple and drill until either the lube dries up or starts to smoke.  Every time that happens, squirt more lube between the tip of the bit and the work piece, then continue patiently drilling.
I've drilled up to 1/2" holes in 1"-thick galvanized, cast, hot-rolled and cold-rolled steel using this method and it works fine.  I developed this methodology after burning up a couple of bits in a drilling experience very similar to yours.  Hopefully it will prove useful for you as well.
Good luck!
Post by: R.G. on May 10, 2008, 10:01:45 AM
Steel is not just steel.  There is a simply incredible variety of steels. Some are so soft,  they are hardly structural at all. Some are so hard that they are difficult to cut even with solid-carbide tools. Some steels turn to butter when you get them red hot. Some tool steels retain their strength so well at high temperatures that they can be used to bore holes in files by friction - the heat melts the file under the bit.
Stainless steel is an interesting one. Even when it's annealed to as soft as it can get, it work-hardens so fast that if you drill it too slowly, it hardens under the bit itself and will blunt the bit. So if you drill stainless, don't dawdle.
Saying "steel" is a little like saying "rock". There's a lot of variety.
Post by: gez on May 10, 2008, 10:27:21 AM
Quote from: R.G. on May 10, 2008, 10:01:45 AM
Yes, this little 'detail' is slowly sinking in!   :icon_lol:
Post by: Paul Marossy on May 10, 2008, 10:44:18 AM
I had a steel amp chassis given to me from some parted out cheapie SS amp that I used to make my Octal Fatness. I had to drill a few holes in it for the tube sockets, and some spade bits made for wood worked just fine, I just had to go slow. Then I have had some other enclosures that I thought were mild steel, but they ended up being some of the hardest things I ever tried to drill!
Post by: timotet on May 10, 2008, 02:07:48 PM
most stainless steels will work harden , as in the surface hardness will increase as you try to drill it especially with a hand drill.
when this happens you can kiss your drill bit good-bye!
with stainless a low rpm (spindle speed) with a heavy chip load (cut) works well with coolant or cutting lube.
make sure your part is held in a vice or clamped to a solid work surface.
it sounds like a small bench top drill press would be a good investment for you! so you dont break your wrist with dreaded hand drill hook up.(ouch)
just my 2 cents :o
Post by: gez on May 10, 2008, 02:39:49 PM
Quote from: timotet on May 10, 2008, 02:07:48 PM
I have one, but it's only for a hobbyist-type-drill (similar to dremel in size).  Great for PCBs, not so great for the aforementioned job.
I think the punch is what I'm looking for: if I was able to drive a nail through the stainless, then a punch should work.
Post by: FisTheGoon on May 11, 2008, 01:16:27 PM
Good topic man. :)
I have experienced such thing.The bit just won't drill thru the steel.Found out that u must start with the smaller bit n gradually  change to bigger bit.Also the speed must not be fast cause it done nothing to the steel.Lubricant is a must to reduce friction.And 1 more thing the drill bit will sure to be blunt after drill and need to be sharpen.Even 1mm thick is a pain in the ass to drill. ;D
Post by: petemoore on May 11, 2008, 02:04:59 PM
  Lube runs down drill shaft, even gets waylayed by...cotton taped there to slowly release a little oil...doing a lot of drilling ? put an oil wick on it.
  Slow and dern stiff pressure +1.
  paper cup for water cooling is an option, hopefully between the oil and the steel cut the heat of the blade is dissipated, but bits soften when temperature exceeds a certain amount.
  For wood, sharpening is an option, for SS, especially for starting, a new bit is the best and only option, new doesn't last very long though...perhaps diamond?..just to get a scratch started?
  I had a pretty good record of bit rate at work, 1 don't break it by bending, 2 use the new bit to get a scratch started, 3 use the good bit to finish the rest of the hole, and oil wick.
Post by: AL on May 12, 2008, 11:04:55 AM
Drill press, some kind of coolant and a lot of patience. Yep.
It's a major PITA drilling with a hand drill. I used to work in a shop and I can't tell you how much fun it is when your electric hand held catches as it goes through... and jerks your hand around with it. It's a miracle I didn't break my wrist. I hated drilling steel.
AL
Post by: Paul Marossy on May 12, 2008, 11:52:30 AM
QuoteIt's a major PITA drilling with a hand drill. I used to work in a shop and I can't tell you how much fun it is when your electric hand held catches as it goes through... and jerks your hand around with it.
I use a hand drill for stuff like that, don't have a drill press. I have learned how to predict that catch when it starts to punch thru and how to deal with it. I've had my wrist jerked a few times before that, too!  :icon_neutral:
Post by: gez on August 16, 2008, 07:13:38 AM
Took possession of the following punch this morning:
http://www.trueshopping.co.uk/product.php?utm_source=froogle&utm_medium=cost-per-click&pid=22211&cid=619&affid=25&utm_campaign=Sealey_Metal_Punch_Set_14pc
Had to place it on the floor and lean on the handle slightly in order to punch the holes, but they came out beautifully.  Re-cut my bracket in a fraction of the time it took the first time round and even modified it to take wider snare wires.  My snare drum sounds great now and the job was neat (I can sleep soundly again).
Post by: DougH on August 16, 2008, 04:50:25 PM
When I used to drill RACO boxes, the keys to successful drilling were:
1. Clamp the work.
2. Use a slow drill speed.
3. Use a high quality and sharp bit.
4. Lubricate the bit.
It's easier with a drill press but I used to hand drill them too, with good results. I punched a dimple in it with a nail set first to center the bit too (which I also do with aluminum).
I don't know how any of this relates to stainless steel.
Post by: gez on August 17, 2008, 08:48:43 AM
Quote from: DougH on August 16, 2008, 04:50:25 PM
If my experience is anything to go by, you end up with very blunt bits, a very hot drill and barely a dent in the material!  :icon_lol:
Post by: arawn on August 17, 2008, 09:36:41 AM
Having Done some machine work as an auto mechanic, the best things you can do are simple good sharp bit suited to the material, cutting oil or 3 in 1 oil, basically any light oil will do adequate pressure, and lots of patience.
The one shop I worked in we drilled a lot of hardened steel shafts, and even with all the conditions right it could take a while,
Don't buy drill bits made in CHINA guys, they lose their edge very rapidly, and they tend to break. High quality european or american made drill bits esp for metal work, Hard materials call for a sharp bit and american and european bits are hardened after they are sharpened so they hold. Asian Manufactured bits are not (cost cutting Measure)
have fun and Happy Drilling!
