DIY Stompboxes => Building your own stompbox => Topic started by: dschwartz on October 23, 2008, 05:31:12 PM
Title: SuperStack tone control!! My new design..
Post by: dschwartz on October 23, 2008, 05:31:12 PM
well. finally i designed a nice tonestack (very nice actually) .. it´s active, versatile, with high, mid, low, and mid shift..
is very simple in concept, needs more parts than a regular tone stack, but i´m pleased with simulations..
This is the schem:
(http://diynoise.googlepages.com/Superstack.gif)
some explaining...
as oposed to typical tone controls, the bass control is a variable high pass, the pot controls the rolloff, at max it rolls off at 20Hz, and at min it rolls off at 1Khz (WAY effective!), the  treble control is a variable low pass, at max it rolls off higher than 10Khz, and at min it rolls off at 1.5kHz..
The mid control is a scoop filter, (thanks STM), it cuts mids around 800Khz, and the shift control moves the scoop between 400Hz and 1kHz
So, it affects the freqs that we want to affect, without any interaction
The tone loss of the passive net is really low!! less than -1.5dB, If you omit the input buffer, any impedance wil alter the frequency responses..
by the way.. this is a great tone control to add as a pedal!!!
Title: Re: SuperStack tone control!! My new design..
Post by: John Lyons on October 23, 2008, 05:56:04 PM
So it's not an active tone control. just buffered and with a make up gain stage.
Looks interesting!
john
Post by: aron on October 23, 2008, 05:59:46 PM
It looks cool to me!!!!!!
Post by: dschwartz on October 23, 2008, 06:07:21 PM
well.. is not really active.. but it will work like one!! haha
Post by: flo on October 23, 2008, 06:20:17 PM
Simple and strait forward, I like it! Especially the mid-scoop adjustable mid frequency.  8)
How would the schematics be if the mid EQ is not a mid-notch but a mid-"hump" version?
Post by: cpnyc23 on October 23, 2008, 07:31:55 PM
nice work daniel!
I know what's going to be on my breadboard this weekend!
-chris
Post by: Ben N on October 23, 2008, 07:51:22 PM
Quote from: flo on October 23, 2008, 06:20:17 PM
Not with the passive stack model, but you can simulate it by cutting highs & lows; or I suppose you can put a scoop filter in the feedback loop of the recovery stage and adjust gain for your mid-boost. But that is a different design.
Nice job, Daniel.
Post by: dschwartz on October 23, 2008, 08:07:12 PM
if you lower the bass and treble, it will give a mid boost around 1.2 kHz..
Post by: dschwartz on October 23, 2008, 08:52:40 PM
idea!
if you place some diodes here & there, this may work as a very nice distortion
Post by: frank_p on October 23, 2008, 09:08:01 PM
You are really productive, Daniel... you should put sunglasses on your avatar.
Post by: dschwartz on October 23, 2008, 10:42:10 PM
hahaha thanks Frank!
i just breadboarded this baby, and put it after a high gain distortion..
my observations:
- sounds great
- it feels like something between a hi fi eq and an amp eq, specially in the way it treat highs.
- i wish the scoop were more pronounced, but it works fine
- bass and treble response is very good, you can feel the hummp going away and the hiss and brightness fading as you turn the knobs
- the mid shift works nice, but obviusly when the mid is scooped..is a scoop shift and not a mid shift.
i am really happy with this, i think i will use it as a standard tonestack for my projects..its unique..
Post by: frank_p on October 23, 2008, 11:21:10 PM
I am going to put your tonestack in my to do list.  But will not box it.  I might put it on perfboard as a block on my "experimentation surface".
Big Thanks !
Post by: Ben N on October 24, 2008, 01:38:03 AM
This is the kind of project that would be great to use with a Guv'nor-style outboard loop built into almost any effect (although not with an actual Guv'nor).
Post by: dschwartz on October 24, 2008, 12:23:58 PM
let´s see if you dig this circuit after you see this frequency response analysis..:
(http://diynoise.googlepages.com/resp.gif)
Post by: GibsonGM on October 24, 2008, 12:38:10 PM
Very nice, Daniel!  Adds some versatility, I know of a few distortions that could use that flexibility....looks like Marshall meets BMP >;o)
Post by: snap on October 25, 2008, 02:23:19 AM
this shows how effective a low source impedance at the input of a tone control works out!
Post by: gigimarga on October 27, 2008, 11:02:24 AM
Nice design!
It is possible to use it directly after a Smash Drive?
Post by: dschwartz on October 27, 2008, 11:19:09 AM
you can use it after almost everything, the input buffer makes it independent of the source...
the only precaution would be not to clip the output opamp, in that case, lower the feedback resistor..
Post by: gigimarga on October 27, 2008, 12:09:47 PM
Thx for your answer...but my question was unclear: i want to use as a  passive tonestack, without the IC  ;D
Post by: dschwartz on October 27, 2008, 12:28:06 PM
oh.. then.. i don´t think so..you need that buffer in the input, or you get a lot of tone loss, and frequency responses changes a lot..
Post by: gigimarga on October 27, 2008, 12:41:35 PM
Thx again...but i made the PCB and i can't find space for an IC...maybe next time :)
Post by: guitarman89 on October 27, 2008, 12:49:04 PM
great work daniel!!! i want to try it!!
Post by: Ben N on October 27, 2008, 03:05:05 PM
I haven't actually sat down and laid it out, but this looks like it would go nicely on one of those Rat Shack IC prototyping boards.
Post by: earthtonesaudio on October 27, 2008, 06:49:01 PM
Thanks for sharing, Daniel!
