DIY Stompboxes => Building your own stompbox => Topic started by: Branimir on February 06, 2009, 08:01:32 PM
Title: Enclosure etching - I need your opinions/tips on this graphic
Post by: Branimir on February 06, 2009, 08:01:32 PM
Hello!
I have never etched an enclosure yet, and think I'm gonna try with a 1590B, a one knob, one switch and a led on the top surface...
Here is my etching template (not mirrored of course, I'll reverse the image to cover the non etching parts)
This is 300dpi jpg, a bit smaller than the 1590B of course...
Is it possible to etch to look like this? Are there to many details? What should I look out for? Are some lines too small? Thanks!
(http://i58.photobucket.com/albums/g249/bbozak/mucha2.jpg)
ps: this is NOT going to be a commercial pedal, I build it for myself and like the works of Alfons Mucha  :)
Title: Re: Enclosure etching - I need your opinions/tips on this graphic
Post by: flo on February 06, 2009, 08:16:57 PM
Perhaps you should remove the "noise" in the white area's and make them totally white again.
Post by: Branimir on February 06, 2009, 08:30:33 PM
Yeah, think I should do it, at least make it less noisy, I tried to print it on white paper and my printer cannot print so much detail (the noise), I should remove much of the noise to make it easier to print, and still to have some dots here and there, dunno... I reckon my etching will be messy so I'll have noise even if I live the space blank! heh
Post by: flo on February 06, 2009, 08:41:23 PM
On the other hand, perhaps the "noise" will come out beautifully! ... decisions, decisions ... ;)
Post by: reverbie on February 06, 2009, 08:50:36 PM
Won't you need to etch with the negative though?
Post by: Branimir on February 06, 2009, 08:54:11 PM
yes of course, i haven't mirrored and inverted this picture, I know i have to make a negative of this to etch it ;)
Post by: rogerinIowa on February 07, 2009, 01:28:19 PM
I think it is totally possible...personally I would clean up the noise a little but that is your call. Cool graphic, too.
Post by: markm on February 07, 2009, 01:39:10 PM
Whatever you decide, it won't come out as crystal clear as the image you have but should be close. If you wish the detail I would suggest not leaving it in the solution very long, keeping it cool and rinsing frequently. A good mask is crucial here.
Both of these involve some detail;
(http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=979&g2_serialNumber=3)
(http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=974&g2_serialNumber=3)
Good luck with it and greetings to all!
  --MarkM--
Post by: Branimir on February 07, 2009, 01:45:21 PM
Thanks, I will reduce the noise, at least my printer won't print it all and it looks a lot better without all those spots and it's still quite detailed though.
I have never etched an enclosure before, how deep does the solution etch into the aluminum?  Btw I have purchased PNP blue, I suppose I have to use a laser printer to print on it, right?
Is there a way to paint the enclosure, but not the etched parts?  Suppose the enclosure is etched and finished, I paint it white with a spray can paint, then I print again the pnp negative and apply it to the painted top, and the paint over the pnp with black? Then removing the pnp by hand, I should get black paint in to the etched parts and white should be under pnp where it was protected? Is this doable?
Post by: GREEN FUZ on February 07, 2009, 02:01:14 PM
Quote from: Branimir on February 07, 2009, 01:45:21 PM
I believe you`ll be opening yourself to a world of frustration by attempting this. You`ll have massive problems with registration not to mention trying to remove the PNP from the white paint. I fear you could end up witha huge mess on your hands. It might be possible if you were using a simpler image.
Good luck in any case.
I`m a huge fan of Mucha too. The image you`ve chosen should work out well although I`d be more concerned with the broad areas of black than the finer lines.
