DIY Stompboxes => Building your own stompbox => Topic started by: cloudscapes on May 02, 2009, 12:09:15 AM
Title: "tall" DIP sockets?
Post by: cloudscapes on May 02, 2009, 12:09:15 AM
hey all,
I was wondering where I could find tall DIP sockets. kind of like stilts. at least three times as tall as the normal ones.
I could piggyback a few normal ones but that wouldn't be neat.
(sneak peak of my next effect, the stilts are needed for the LED display) (http://soniccrayon.blogspot.com/2009/04/hollow-earth-v2-populated-pcb.html)
Title: Re: "tall" DIP sockets?
Post by: Joe on May 02, 2009, 01:31:31 AM
Maybe wirewrap sockets, they can be pretty tall sometimes:
http://www.mouser.com/Search/ProductDetail.aspx?qs=%252bMZ9mQjsYosT%2fvC21Tf78A%3d%3d
Post by: aron on May 02, 2009, 02:02:08 AM
What about the SIP sockets I have in the STORE link above?
Post by: Nitefly182 on May 02, 2009, 02:59:46 AM
Quote from: Joe on May 02, 2009, 01:31:31 AM
$9 each  :icon_eek:
Post by: puretube on May 02, 2009, 04:31:47 AM
@digikey (http://parts.digikey.de/1/1/790502-ic-socket-14-pin-wire-wrap-300-123-43-314-41-001000.html)
conrad-diy-solution (http://www.conrad.de/goto.php?artikel=739111)
you need to be a pro for the following:
http://www.buerklin.com/gruppen/KapB/B102595.asp
http://www.buerklin.com/gruppen/KapB/B102620.asp
http://www.buerklin.com/gruppen/KapB/B102600.asp
http://www.buerklin.com/gruppen/KapB/B090500.asp#B090520
or else google for "wire-wrap"- or "LED"-sockets...
Post by: cloudscapes on May 02, 2009, 11:22:36 AM
thanks guys, lots of choices.
some of them look close to what I need (at least half-inch tall)
Post by: slacker on May 02, 2009, 12:05:12 PM
How many pins do you need? I've got some 14 pin wire wrap sockets that are about 23mm from the top of the socket to the bottom of the pins.
If they would be any use PM your address and I'd be happy to send you a couple.
Post by: tranceracer on May 02, 2009, 01:40:03 PM
How about something like these from Mouser:
Dual-in-line Sockets:
http://www.mouser.com/catalog/638/1494.pdf (http://www.mouser.com/catalog/638/1494.pdf)
3 Level Wire wrap Sockets:
http://www.mouser.com/catalog/638/1493.pdf (http://www.mouser.com/catalog/638/1493.pdf)
