DIY Stompboxes => Building your own stompbox => Topic started by: AM on May 25, 2009, 09:22:25 AM
Title: Dano's Stutter Box and Splitter Box in one enclosure
Post by: AM on May 25, 2009, 09:22:25 AM
I want to build a Splitter Box and Dano's Adjustable Stutter Box in one pedal.
For the Splitter Box I will use the first half of this:
http://runoffgroove.com/splitter-blend.html (http://runoffgroove.com/splitter-blend.html)
Dano's Adjustable Stutter Box wiring diagram is here:
http://www.beavisaudio.com/projects/StutterPedal/index.htm (http://www.beavisaudio.com/projects/StutterPedal/index.htm)
I would put the Stutter Box's Switch and pot first followed by an other switch to give me the option of turning on and off the buffer circuit when I need it. When the buffer / splitter circuit is off the signal would simply go to one of the two outputs.
I have a question though. Do I need to add any components to either circuit to match them without issues? Should I change the pot value or anything else? I want to be able to use the box first or last in my pedal chain so flexibility is essential.
Thanks in advance for reading and posting.
Title: Re: Dano's Stutter Box and Splitter Box in one enclosure
Post by: AM on May 26, 2009, 01:03:14 PM
103 views and no answer ??? I thought it was an easy question :icon_frown:
