DIY Stompboxes => Building your own stompbox => Topic started by: Paul Marossy on September 07, 2009, 02:24:45 PM
Title: Ibanez PH99 Bypass Switch
Post by: Paul Marossy on September 07, 2009, 02:24:45 PM
Does anyone know if the bypass switch is a momentary type or not? And if so, if it is a N.O. or N.C. type?
Title: Re: Ibanez PH99 Bypass Switch
Post by: captntasty on September 07, 2009, 06:30:59 PM
I'm pretty sure it is momentary - check this schematic:
http://www.dirk-hendrik.com/temp/ibanez_ph99.pdf (http://www.dirk-hendrik.com/temp/ibanez_ph99.pdf)
Post by: Paul Marossy on September 07, 2009, 06:33:19 PM
I have that schematic, but it doesn't say anything about the actual type of switches used...
Post by: captntasty on September 07, 2009, 07:10:17 PM
I get it - open or closed....
Post by: Paul Marossy on September 07, 2009, 10:28:08 PM
Looking at the schematic, it leads me to believe that it is a standard DPDT switch instead of a momentary type since there appears to be no transistor acting as a switch for the bypass status LED.
Post by: Paul Marossy on September 12, 2009, 10:40:46 AM
Just for the record, I did verify that it is just a standard DPDT switch. The one on my bench has a Carling X-type DPDT switch on it.
