Hi. I have used a beavis board project to make a fuzz face on my breadboard and have made all the mods and stuff i want and its sounding great. Its just im having trouble trying to start putting the thing onto veroboard. I have looked at som veroboard layouts for the fuzz face but they all seem to have an IC in it and my circuit doesnt (tell me if i am wrong). Here is the layout i found:
http://www.aronnelson.com/gallery/main.php/v/DRAGONFLY-LAYOUTS_0/album18/album144/SILICON_FF_VERO_001.gif.html (http://www.aronnelson.com/gallery/main.php/v/DRAGONFLY-LAYOUTS_0/album18/album144/SILICON_FF_VERO_001.gif.html)
Am i right in saying the thing with six holes at the bottom is an IC?
Because my circuit i made on the breadboard doesnt have an IC.... :
http://www.beavisaudio.com/bboard/projects/bbp_FuzzFace_Rev1_1.pdf (http://www.beavisaudio.com/bboard/projects/bbp_FuzzFace_Rev1_1.pdf)
Can someone tell me what to do to get this circuit on veroboard?
Thanks everyone :)
That is the switch ;D , it is a standard DPDT footswitch. If you are using a 3PDT so you can have an LED then there will be a third row.
That layout is fine.
good luck
sorry for old thread request:
could someone spare 2 minutes and label in/outs for me on this layout? yes i see the jacks, but some of these jack drawings confuse me as they look different than others i've seen. I would like in and out labeled on the wires if someone will be so kind. Thanks!
(http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=10880&g2_serialNumber=2)
Dark Purple Wire & Jack on the Right is the Output. Green Wire is Ground, which leaves the input.
You know because it comes straight off the volume pot, usually the last or one of the last parts of a circuit ;)
Also, check a schematic and you can work it out easily.
thanks for the help. the way the jack connections are drawn, i could not tell which color is going to tip/sleeve/ring. i have other jack drawings that are much more apparent. thanks!
