I'm wondering if someone could provide a pointer to solderpins including the female part with a diameter of < 1mm. Thanks!
-Piet
Piet, wat bedoel je eigenlijk....?
Maarten
Quote from: maarten on April 09, 2010, 07:35:34 AM
Maarten
Maarten,
In most cases the plated through hole is 1mm to accomodate for a 1mm round "shaft" form type of solderpin. The area below the rim is to be inserted into that hole while the top part is the interface to a female part (your wire connector). The 1mm assumes it's a press-fit mount. When applied to a plated-through-hole specified for 1mm this is too small hence press-fit will damage the hole .
Kind Regards (groetjes)
Piet
These perhaps:
http://www.sparkfun.com/commerce/product_info.php?products_id=743
I need some too so perhaps we can share an order. ( I'm the same ~arph as on newtone-online )
