Hello
I'm currently building my first effect (on a breadboard), but i'm having some problems. One of the possible causes could be that i wired the input & output jack incorrectly. Im working with this ( http://www.velleman.eu/distributor/products/view/?id=340810 ) type of jack, and i'm following this ( http://www.aronnelson.com/gallery/main.php/v/DRAGONFLY-LAYOUTS_0/album18/album144/BAZZ_FUSS.jpg.html ) schematic.
Could you guys explain to me which connectors on the jack are the sleeve, ring and tip?
Thanks! :)
Hello,
Please see this topic (http://www.diystompboxes.com/smfforum/index.php?topic=86012), where you will find the answer. Ronsonic's post pretty much sums it up. :)
Good luck!
Mike
Can be verified, but helps if knowing what to look for with DMM, cable[s Jacks, the jacks can do different things, trick is to get 'em doing exactly and only what you want them to, related to various conditions [inserting plug may change jack connections].
Follow the tip/sleeve [ring?] wipers through the bottom [ under good light], any switch wipers.
Velleman link showed a ''country?'' page.
Quote from: petemoore on August 24, 2010, 08:20:02 PM
Sorry for the link not working, heres an image of the jack i'm talking about.
(http://www.velleman.eu/images/products/11/small/ca046.jpg)
And thank you Mike for that link, i didnt find it with the search.
