I was going to try making a simple L-Pad attenuator for my Little Giant. Is this how it should be hooked up? I also heard something like a 4uf cap can be added to bring back some of the highs. How would that be wired in?
(http://i266.photobucket.com/albums/ii249/ghobii/attenuator.jpg)
Wiring looks good.
Put the cap across the green wires to retain highs as you roll the l-pad back. Experiment with values - you may even find that you like it without
So I built this thing, works great. I added the 4uf cap across the the L-pad(green wires in my drawing) and wasn't sure I was hearing much of a difference. So I put in a switch and found that the cap..it does nothing! I just clipped one of the caps leads and inserted a spst switch. That should work right?
