DIY Stompboxes => Building your own stompbox => Topic started by: angelodp on January 02, 2011, 04:46:43 PM
Title: Ibanez FL-301 trouble
Post by: angelodp on January 02, 2011, 04:46:43 PM
Hi, new to this forum and could use some help fixing an old Ibanez FL-301  Flanger. The board inside says Maxon MP FL0401A. I do believe that I inadvertently put a mismatched power supply on the unit and it does not light up anymore. I am looking to trouble shoot the pedal, any help would be greatly appreciated.
I think it just might be the Polarity protection diode?   How do I test for that... better yet find it.
"It's quite common for a polarity protection diode to short. Be suspicious of these if you have a power problem."
best  A
Title: Re: Ibanez FL-301 trouble
Post by: Bullet79 on January 02, 2011, 07:58:57 PM
i'v build a couple FL-301's Flanger... the diode is one thing,.. but i'm sure you got the 12v regulator fried.. and the p.diode should be close...
Post by: angelodp on January 02, 2011, 08:34:36 PM
Ok, thanks. Can you tell me how to check for that diode and what it looks like ( its location )... any additional diagnostic help is appreciated.
A
Post by: Govmnt_Lacky on January 02, 2011, 09:50:30 PM
A good picture of the circuit board component side or a link to the schematic would do wonders!  ;)
EDIT: Just looked up the schem. Looks like the protection diode is D104 and the regulator is IC106. Here is a link for your board
http://sites.google.com/site/matthewkloiber/schematic.GIF
Post by: angelodp on January 02, 2011, 11:18:47 PM
I have taken reading to ground of just about every node, except diode 102 ( which reads .02vdc ), reads 17+ volts.  I have never done any trouble shooting on a pedal so I do  not know if this is on the right track.
Post by: angelodp on January 03, 2011, 12:32:33 AM
All nodes except the spot in red in the middle of the board ( solder side ) read 9v.... the red arrow juncture is at .02v
(http://i260.photobucket.com/albums/ii9/angelodp1/Top-side.jpg)
(http://i260.photobucket.com/albums/ii9/angelodp1/Rear-connections.jpg)
Post by: Govmnt_Lacky on January 03, 2011, 08:23:45 AM
Quote from: angelodp on January 02, 2011, 11:18:47 PM
Angelodp.... I don't quite understand what you are trying to say here however, what you should do since you believe you installed a wrong power supply is to trace the power from the board input (DC jack) and look for a diode that goes from the power path (striped side) to ground (un-striped side). Check that diode and ensure that you have input power on the striped side and ground on the un-striped side. If you do not have these readings then, that power protection diode is bad.
Next, check your voltages and ground at the 12V power regulator. That is the part that looks like a transistor that is closest to your DC jack (in your picture) that is labeled 78L12. With power applied, you SHOULD read DC input power on one of the outside legs, ground on the middle leg, and 12VDC on the other outside leg. If you read anything else then the 12VDC regulator is bad.
After that, I suggest you follow the "What to do when it doesn't work: Debugging" thread. Here is a link:
http://www.diystompboxes.com/smfforum/index.php?topic=29816.0
Good Luck and be sure to post back if you find the problem so others can learn.  ;D
Post by: angelodp on January 03, 2011, 11:49:45 AM
Hi, can you define striped and unstriped side please. Are the diodes the little cans with the chopped off edge.
Post by: Govmnt_Lacky on January 03, 2011, 11:53:51 AM
Quote from: angelodp on January 03, 2011, 11:49:45 AM
I can only help you SO much dude!
You need to learn the basics first. This is a DIY site after all. I would suggest you use Google to find out the shape, sizes, differences etc. between diodes, capacitors, transistors, resistors, etc.
Just Google diode and it will show you the way....... along with many other facts  ;D
Not trying to sound like a jack-hole but if you do not know what the components even look like..... then ALL OF US on here will have an incredibly HARD TIME helping you from here on out.
Post by: angelodp on January 03, 2011, 11:56:52 AM
I know what caps and resistors look like, but I am not familiar with the type of diodes used in these pedals. could you simply point one out please. I assume the little cans with the chopped off tops?
Post by: Govmnt_Lacky on January 03, 2011, 12:07:34 PM
In your pictures above... the top picture of the component side. Look just to the left of the black arrow tip. You notice a small ORANGE component? It is mounted vertically and it has a small black stripe on one end of it. That is one of the diodes that are in the circuit.
Post by: angelodp on January 03, 2011, 12:10:55 PM
Ok, sorry, my eyes are not what they used to be. I see that now. OK ... I will go back to your recommendations on reading voltages and report back.
Post by: angelodp on January 03, 2011, 07:11:29 PM
Checked all diodes and they are fine. The 12v power regulator however does not read according to your notes. I get 18v on all three pins. Looks like its gone south, would that be correct.
"Next, check your voltages and ground at the 12V power regulator. That is the part that looks like a transistor that is closest to your DC jack (in your picture) that is labeled 78L12. With power applied, you SHOULD read DC input power on one of the outside legs, ground on the middle leg, and 12VDC on the other outside leg. If you read anything else then the 12VDC regulator is bad."
Post by: twabelljr on January 03, 2011, 07:59:25 PM
If you are reading 18V on the center pin then it seems you have a ground problem. Where are you touching or hooking the black lead of your meter when taking these measurements?
Post by: angelodp on January 03, 2011, 08:03:29 PM
I have the black meter lead on the black wire of the input jack.
Post by: twabelljr on January 03, 2011, 08:05:32 PM
Do you have continuity from the jack to the bottom of pad 14?
EDIT: Print that schematic Govmnt_Lacky found for you. The center pin of IC106 should have continuity to ground (anything with the diagonal hashmarks should be grounded). Do your continuity tests WITHOUT power applied to the board.
Post by: angelodp on January 03, 2011, 08:34:04 PM
You mean the power jack... yes. Yes I have the schematic. The center pin of 106 does not show continuity to ground.
Post by: twabelljr on January 03, 2011, 08:50:19 PM
QuoteThe 12v power regulator however does not read according to your notes. I get 18v on all three pins.
I think you need to check the board grounds. If you read 18v on the center pin of the regulator then it is not grounded. Something blew or burnt. Trace from the jack to where the black wire connects to pad 14, if good then follow the trace from pad 14 to the regulator common. (center pin). That's about all I got. Hope it is of some help. Good Luck!!
Post by: Govmnt_Lacky on January 03, 2011, 10:36:47 PM
Quote from: angelodp on January 03, 2011, 08:34:04 PM
The center pin of the 12V regulator (IC106) SHOULD READ CONTINUITY TO GROUND! If it does not, then that is a problem that needs to be fixed BEFORE moving on. DO NOT continue on without finding and fixing this problem. If you do you will just end up chasing your tail.
I would recommend checking for a bad solder joint on the center pin of the regulator to the circuit board. Next, you should check the ENTIRE board run from the center pin of the regulator ALL THE WAY back to where it connects to the ground input. If that ALL checks out, then replace the 12V regulator.
Instinct tells me that you have killed the regulator with the suspected wrong power supply that you say you plugged in BUT, you should take the time and investigate the circuit BEFORE jumping to replacing the part.
Good Luck and report back with what you find.  ;D
Post by: angelodp on January 03, 2011, 10:39:16 PM
Will do, is that part readily available. Small Bear?
Post by: Govmnt_Lacky on January 03, 2011, 10:42:09 PM
Quote from: angelodp on January 03, 2011, 10:39:16 PM
Definitely.
Where are you at? If I can dig up one I will send it to ya if it is not too expensive.  ;D
Post by: angelodp on January 03, 2011, 10:43:22 PM
Wow, you are a gentleman and a scholar. I am in Los Angeles
Post by: Govmnt_Lacky on January 03, 2011, 10:53:00 PM
Sent you a PM angelodp
Post by: Bullet79 on January 03, 2011, 10:59:49 PM
last resort........
(http://i298.photobucket.com/albums/mm276/brownsound79/Top-side2.jpg)
(http://i298.photobucket.com/albums/mm276/brownsound79/Rear-connections2.jpg)
if all still not working, please consider to buy a new pedal.. or build one........  :icon_mrgreen:
Post by: angelodp on January 03, 2011, 11:17:31 PM
Ok Diode is still ok but that 12v regulator is blown. Are you saying with that blown it may have caused additional damage down the line and it is not repairable?
Thanks all for helping out.
Post by: Govmnt_Lacky on January 03, 2011, 11:24:04 PM
Quote from: angelodp on January 03, 2011, 11:17:31 PM
Nothing is for sure right now EXCEPT the fact that you have identified a bad 12V regulator. That needs to be dealt with BEFORE moving on.
Did you get my PM?
Post by: angelodp on January 03, 2011, 11:26:07 PM
Yes, and very good... looking forward to the minor surgery lol.
:icon_razz:
Post by: Govmnt_Lacky on January 03, 2011, 11:28:42 PM
Quote from: angelodp on January 03, 2011, 11:26:07 PM
:icon_razz:
Did you RESPOND to the PM I sent? I did not receive a reply.
Post by: angelodp on January 03, 2011, 11:38:45 PM
Yes did you get it.
Post by: angelodp on January 07, 2011, 07:56:45 PM
Big thanks to Greg for helping me out on this. Put in the 12v regulator ( ;) now I know what it is ) and whamo Flanger back. Now I do not have the light working, LED so I do need some help on that. While the unit was down I did try a 9v battery on the LED to see if it worked and it did... hope I did not fry that? Any thoughts.
BTW, just a note of special thanks to Greg and a forum that is kind and civil.
Best Ange
PS on a one spot, is there a tip that will work with this unit?
PPS I cannot make out the symbol of the LED on the schematic?
Post by: angelodp on January 07, 2011, 10:50:46 PM
Ok so the pedal works but not the LED. Took out the protection Diode and it is working ok out of circuit. In circuit it is passing voltage in both directions. I think the problem may be a sloppy soldering
job done by a tech a while back when he was trouble shooting the pedal... never did fix it. But it looks like the solder has slopped over and is making some bad connections. Not sure how to get that solder out of there . I have tried braid and
solder sucker but a thin sheet remains and is making contact where it should not... I think.
Any suggestions would be great. The pedal works.
(http://i260.photobucket.com/albums/ii9/angelodp1/IbFl-solder.jpg)
Post by: Govmnt_Lacky on January 08, 2011, 05:34:04 PM
Your best bet would be to remove any questionable solder with either the braid or a solder sucker. Do this the best you can. Then, USING THE SCHEMATIC.... cut or remove  the "bad" traces with an exacto knife. After you have confirmed that ALL of the "bad" traces have been severed (ensuring connections are good in accordance with the schematic).... then resolder and re-check.
Odds are that the traces that are UNDER the boards coating are good. You just need to worry about the "questionable re-work" that was done.
Good Luck  ;D
Post by: angelodp on January 08, 2011, 07:43:11 PM
Greg, yeah it was the LED, threw a new one in and its all back to working like new. Now the One Spot tip is still a question. AFAYK ... does this unit require a positive tip or negative tip power source.
Thanks  Ange
Post by: Govmnt_Lacky on January 08, 2011, 07:56:12 PM
Should be easy to find out. Just check for continuity with your DMM from the input of the 12V regulator (the leg that reads 18V... which SHOULD be the leg closest to the DC jack) to either the DC jack tip or outer ring. That should tell you if the tip is V+ input or the ring is V+ input.
BTW... do this with batteries removed and no power applied.
Good Luck  ;D
Post by: chuckfalcon on April 03, 2016, 10:33:25 AM
Hey guys, I too have a FL-301 problem that I haven't really dove into yet.  I have checked the debugging page and it doesn't cover the issue that I am having.
The issue is, I have a substantial volume loss when I use this pedal "on" AND bypassed.  I know this pedal isn't true bypassed in bypass mode, so the issue is happening in circuit somewhere.
Any idea what in the world this could be?
Thanks,
Chuck
