DIY Stompboxes => Building your own stompbox => Topic started by: leopoldoghost on February 12, 2011, 05:53:39 PM
Title: Mission 1: Blue Clipper
Post by: leopoldoghost on February 12, 2011, 05:53:39 PM
Hi Everyone,
this is my very first project, and, as it should be, it doesn't work  ;D
Now, i've read the Debugging guide (god bless the writer), and i' ve found out some "malicious" components (and replaced' em).
Still don' t working...  :icon_confused:
I have some suspects for the IC...
well, i really can't get out from this situation, so, i'm imploring community's help
According To DEBBUGGING Guide:
1 - [ISSUE] no sound at all (i'm unsing no bybass)
2 - [CIRCUIT NAME] Blue Clipper
3 - [CIRCUIT SOURCE] http://www.tonepad.com/getFileInfo.asp?id=93 (http://www.tonepad.com/getFileInfo.asp?id=93)
4 - [CIRCUIT MODIFICATION] NO
5 - [PART SUBSTITUITIONS] YES:
R1 -> 220k
R2 -> 270k
R6 -> 12K
Equivalent Diodes (cant' remember the name :P)
6 - [GROUND CONVERSION] NO
7 - At this point, i should've posted the voltage for each pin of each component but i've noticed something strange.
     in some components, the voltage is 0.00 (?)
     If this can be useful, i can write the full list, but now (Hoping that my suspects are founded) i'll write just the IC's voltages
TL071 (8pins)
approx. 9,52V DC IN (Battery)
pin 1: 0,05
     2: 9,10
     3: 0,00
     4: 0,05
     5: 0,00
     6: 0,59
     7: 0,00
     8: 0,00
(pins 3,5,7,8 seems to be dead, not, as 4 and 1 that moved a little my multimeter)
thanks in advance for the Help  :)
Title: Re: Mission 1: Blue Clipper
Post by: PRR on February 12, 2011, 06:19:54 PM
Substitutions are fine.
Did you use TonePad's board? Or etch your own? Or perf-boardf?
Pin 7 is supposed to be +9V. It comes right from the battery via any switch, jack, or other stuff, to "+9V" on PCB then a half inch trace to IC pin 7.
Pin 2 must NOT be +9V; this says there is something else wrong (which is why I wanna know what board you use).
Post by: leopoldoghost on February 13, 2011, 03:00:05 AM
I' ve used a Stripboard, than, "draw" the circuti on it.
some photos can be useful?
