DIY Stompboxes => Building your own stompbox => Topic started by: petemoore on May 29, 2011, 12:19:48 PM
Title: -grid supply, 7809 or 7808 '~=''?
Post by: petemoore on May 29, 2011, 12:19:48 PM
  6sn7 as best I can find info for wants a -8v grid supply.
  290v plate supply...6.3 spot on for heaters, I just need the -8 [very DC-like] to bias the grid with instead of the battery [chuckles.
  I have an amplifier working, sounds extrodinarily nice, the simple easy [less than reliable] way to bias grid, a weak battery !
  I tried and debugged pretty good I think the 2w PP poweramp at ax84 but got -3 volts out of that. I don't understand how it works exactly to debug it...kind of just a couple diodes from 1/2 of a secondary tap...a string of resistors and filter caps..pretty simple, I though of 'adjusting' it but decided to either figure that, or an alternative out.
   For now the battery is on a switch, and the low gate current...not too worried...just don't try it at home without measuring the battery...my tube was redplating with a 3v grid bias.
Title: Re: -grid supply, 7809 or 7808 '~=''?
Post by: Gus on May 29, 2011, 12:38:04 PM
I am not understanding your post there is not enough information
Are you using the 6sn7 as a dual triode output in a push pull amp?
The 6.3 volts AC or DC?
You don't want to cathode bias but you want fixed bias?
Post by: petemoore on May 30, 2011, 12:05:09 AM
   It's the AX84 2w Push Pull amplifier schematic, in Building Blocks section
  Yes, it sounds very good.
  AC..from secondary tap for the heaters.
  Yes, I'd like to try one, I have an LM317 here, there's room for another small transformer/rectifier/filter also...I was thinking just get 11 [or so] AC volts going then 'bend it down' to the 8volts I want for the fixed negative bias using the regulator [or string of diodes].
   I've only tried this once, this time, using a battery for it's floating ~8.5v to
-bias the PP output grids.
  The amp has 3x 6sn7 in it. One for preamp stages, one for phase inverter, The -bias is only for the grids on the PP output.
Post by: merlinb on May 30, 2011, 05:26:30 AM
Quote from: petemoore on May 30, 2011, 12:05:09 AM
That bias supply in the schematic does exactly that- it takes the AC voltage of the transformer and half-wave rectifies it to make a negative DC voltage. Why on earth would you want to add another transformer/rectifier/regulator when you already have a system that does the same thing, and just needs to be trouble shooted??? It's only got one diode, a couple of resistors and a couple of capacitors, it can't be that hard to find what you've wired wrong!
Post by: petemoore on May 30, 2011, 09:01:56 AM
  OT:
 Incorrect, I don't already have a system that does the same thing.
  I have an already crowded PS Section, I don't intend to attempt re-threads of added circuitry, much less debugs in that area, I have strong preference for 2 disconnected primary connections debugged [ie make sure the primary is good, test the secondary/isolate connections to AC120plug], then nice low tension voltage via Stancor w/LV secondary, outside the powersection and amplifier entirely, to debug and measure to hearts content...and as a way to defy the prevailing logic, having a cute little Stancor Iron, a 317 variable regulator, a 5k pot that could provide more lug/stays for the grid bias circuit + allow me to alter grid bias [for personal reasons such as why not, easier than askin' exactly what does grid bias drift sounds like]. BTW sounded pretty bad @3v.
 Yea, figure break it down, work with it at low voltage is asking for less trouble.
 Yep, I can count the nodes connections on that circuit by now, even without the cheat sheet.
  In the meantime with the battery it works great.
Post by: merlinb on May 30, 2011, 10:02:38 AM
Quote from: petemoore on May 30, 2011, 09:01:56 AM
Sorry, I have trouble understanding your posts, I assume English is not your native language. You said
"I tried and debugged pretty good I think the 2w PP poweramp at ax84 but got -3 volts out of that."
So did you not build the whole circuit shown here?
http://ax84.com/static/corepoweramps/2W_PP/AX84_2W_PP_Poweramp_Schematic.pdf
But adding another transformer and PSU circuit will make it even more crowded and complicated...
Quote+ allow me to alter grid bias [for personal reasons such as why not, easier than askin' exactly what does grid bias drift sounds like.]
But the original AX84 circuit already has an adjustment pot (VR1) so you can alter the grid bias. If you build it correctly, it will give you much more than -3V
Post by: petemoore on May 30, 2011, 11:07:59 AM
  I know better than to be so hasty...but sometimes I still am.
   Anyway, I thought it over again and decided I can do a proportional voltage.
  Build the little circuit rectifier/filter/filter divider adj./10k>Gnd. ...bias divider string outside the box, test it at say 4v, do math for a minute, then another, place that in the open spot inside the chassis, connect it to the PT...test it in there.
Post by: merlinb on May 30, 2011, 02:46:06 PM
QuoteInstead of going OT in my threads:
 If you want to discuss your problems start your own thread, plain enough english for ya ?
 If you feel the need to urge others to cram circuits into already crowded HV sections of 'expensive' [cost me like 30 buxx, 3 days @ 8 hours a day], amplification, start your own thread to do it.
 Even if you want to praise the design of the 2w PP amplifiers grid bais section, I don't care about it...start your own thread for that too.
Now I'm plain bewildered.
Post by: petemoore on May 30, 2011, 06:15:29 PM
   Perhaps you can open your own threads for english grading, bewilderment training and advanced thread hijacking techniques.
   You've done a real wiz-bang job here, your skills, by the book that doesn't work and hostility toward experimentation are no longer wanted or needed here.
