Now here's a circuit I'd very much like to try out. Here, I drew it up in Eagle, if anyone feels like experimenting with it.
http://www.4shared.com/file/NpBJAuK7/BISFOL.html
My most important question is this: could the performance improve if I applied my favourite technique of full-wave-rectifying the signal once or twice before feeding it into the circuit?
I've replaced the CMOS IC with half an opamp. The EDN article says:
QuoteTo ensure that one of the detectors holds the highest peak value for the entire input period, the reset clock period is slightly longer than one-half the period of the lowest input frequency.
So for a minimum frequency of, say, 100Hz, do I tune the oscillator to 3*55Hz or 4*55Hz?
I'll also probably convert it to a single supply power rail when I get to building it - looks like an easy mod.
Quote from: egasimus on August 18, 2011, 05:39:55 AM
So for a minimum frequency of 100Hz, I'd tune the oscillator to 55Hz or something?
You'll probably have more input if you just link to the pdf file...
http://www.edn.com/file/18042-122602di.pdf (second article in that pdf file)
Re your question, yes full wave rectification will have less ripple & therefore perform better ....two lots of full wave rectification to me seems a tad excessive!
Re the frequency of the reset clock.....yes your calculations to me seem right.....but that's
per 'peak detect' stream
My actual question about the frequency was more along the lines of whether I multiply the 55Hz by 3 or 4, given that the IC's 4th output is connected to the reset pin... My bad :/
And, double FW rectification might be overkill for a guitar, but it doesn't hurt - and a bass's low E was something like 38Hz, so it might help there.
