DIY Stompboxes => Building your own stompbox => Topic started by: carboncomp on March 08, 2012, 01:30:21 PM
Title: Diy multi Power Supply?
Post by: carboncomp on March 08, 2012, 01:30:21 PM
Hello!
Really need to build a multi Power Supply for my pedalboard like the AMZ power supply (http://www.muzique.com/images2/power7.gif), anyone got a vero layout or schematic for something similar WITH all the values on it?
Title: Re: Diy multi Power Supply?
Post by: carboncomp on March 08, 2012, 09:38:54 PM
......and instead of tacking on multiple +9v off from the single regulator, could I instead run multiple -9v from the IC1 (MAX1044???).
Post by: carboncomp on March 10, 2012, 03:19:14 AM
Bumpy bump bump  :icon_mrgreen:
Post by: Andr3as on March 10, 2012, 06:48:23 AM
My suggestion is that you find a 9-18V PSU that you don't need, cut it open and use some LMxxx DC regulators to get the voltages you want...
It's a tight fit, but i squeezed a LM7809 into a PSU for 12v, and got 9v regulated out.. Also added a pink LED for the mojo  :icon_wink:
Post by: darron on March 10, 2012, 07:29:42 AM
Quote from: carboncomp on March 08, 2012, 09:38:54 PM
from memory you can draw bugger all current from a max1044... so maybe not a good idea.
Post by: Mike Burgundy on March 10, 2012, 08:24:57 AM
Check the spyder PS at GEO. Built it using a sackfull of small 9V transformers (rated for 9V, turned out to have enough overvoltage at load after rectification, churns out regulated 9VDC like a charm), two regulators per transformer output so I have isolated groups of 2. Anything you want to add-on (12V - use an appropriate transformer and regulator/sag use an adjustable regulator/positive ground neg regulator on isolated group - no need for charge pumps etc) should be straight forward.  Has the added bonus of isolated groups to prevent ground loops.
edit: spelling, and overvoltage
