DIY Stompboxes => Building your own stompbox => Topic started by: pitchwest on March 14, 2012, 06:32:08 PM
Title: Sonic tick. LM555 Tremolo
Post by: pitchwest on March 14, 2012, 06:32:08 PM
I'm working on this circuit. It's my first time with the LM555. After playing around with it, I have it doing what I want... almost. It's acting as a tremolo for a fuzz circuit. It produces this horrible ticking though. I thought that if I could soften the on/off square wave of the LM555 that that would help. How would I soften the wave and or extinguish the ticking?
Title: Re: Sonic tick. LM555 Tremolo
Post by: frequencycentral on March 14, 2012, 06:33:50 PM
Replace with 7555. No crowbar.  ;)
Post by: R.G. on March 14, 2012, 06:34:14 PM
Change over the CMOS version of the 555. The NE555, LM555, and other bipolar versions are (in) famous for pulling monstrous pulses of current through power and ground when they switch. That is one likely source of your tick.
Post by: smallbearelec on March 14, 2012, 06:49:00 PM
This design:
http://www.smallbearelec.com/Projects/TremBear/TremBear.html
incorporates a number of design elements (including the use of the COMS 555) that make it blessedly quiet.
Regards
SD
Post by: smallbearelec on March 14, 2012, 06:58:48 PM
Quote from: smallbearelec on March 14, 2012, 06:49:00 PM
This design:
incorporates a number of design elements (including the use of the COMS 555) that make it blessedly quiet. I used R. G.'s suggestion of separate ground busses for oscillator and modulator, joined only where the negative supply lead enters the board. There's also a simple power supply decoupling network for the LFO, and a snubbing capacitor (C9) that rounds off the edges of the output of the 555.
Regards
SD
