Projects => IC-based Overdrive => Topic started by: Otsismi on July 29, 2013, 09:46:18 PM
Title: IC OD lacks sustain
Post by: Otsismi on July 29, 2013, 09:46:18 PM
I find that my lm741 overdrive circuit, while it produces wonderful distortion does not give me the increased sustain I get from pedals I try at the shop. I feel like the diode clippers are actually taking much of the leftover signal after initial attack and clipping it therefore it seams there is not sustain. Maybe I don't know what I'm taking about. Just thought others might have some insight
Title: Re: IC OD lacks sustain
Post by: cruisemates on June 27, 2014, 06:07:58 PM
I am also just a beginner - but I can tell you I built the Brian May booster which has no ICs or Diodes - just a single NPN transistor - and I got an unbelievable amount of sustain. I found it hard to believe such a siumple circuit could be so effective but so far it is one of the best I have tried; including the DOD, the LPB and even a KLONe. Here is a link to it: http://www.beavisaudio.com/bboard/projects/bbp_BMTrebleBoost.pdf
Once again, I sure would like to see more answers in this forum, there is a lot of potential here.
Post by: vigilante397 on June 27, 2014, 08:00:00 PM
First of all, welcome to the forum :) Second of all, both threads you have posted this about were questions that had either been addressed in prior threads and the author did not use the wonderful "Search" function before posting or they do not contain the necessary information (links, schematics, etc.) for forum members to give proper help.
Cheers  ;D
