Latest breadboard experiment is turning into a keeper. I started trying out a bunch of different popular "One Knob" fuzzes and gradually it morphed into this.
C1 treble bleed allows a nice variety ranging from crunchy OD to thick beefy fuzz.
Tone control is just a BMP but the magic happens when I throw the "Mid Shift" switch to go from scooped death metal rhythm tones to fat cranked Marshall leads.
It certainly does not need a "make up gain stage" but do you guys think it could benefit from an output buffer?
(https://s26.postimg.org/jwi1a92i1/Meathead_w_mods.png)
Love the one knob fuzz...in any variation :-)
I would try a recovery or output buffer..
I asume the BMTS took a lot of output volumen.
I would take the traditional BM stage and tweak the emiter resistor to get an LPB (tons of output)
I like BMP type tone controls at the output collector as Ben has posted. The output off the collector is high enough not to need a following gain stage.
You can check how things change with spice with different output loading
or
You can test what the next effect/amp input resistance will do to the eq.
I would start with an amp that has a 1meg input. I would then add different resistors in parallel with the amp input try a 1meg then 470k then 220k etc.
Test at different setting of the tone and volume.
R7, R8, (R9, R10) are a DC path to ground from Q2 collector. Was this on purpose?
It should not matter much because you have a cap to the volume control wiper and the resistance is higher than the 5.6k output
IIRC There was a thread at the forum in the past where someone had a DC resistance to ground from a collector output and they posted it sounded better DC coupled vs AC coupled
I think it was an adjusted 360 fuzz.
Quote from: Plexi on September 11, 2017, 01:38:00 AM
Plexi, it sounds like a Tone Bender, I did not know that the One Knob Fuzz had so much fuzz in it until I breadboarded it.
It really does not need any extra volume stages, as Gus noted, it takes off from Q2c and has so much that the BMTS is a welcome adjustment
Quote from: Gus on September 11, 2017, 05:12:18 AM
or
Gus, that's a great idea about paralleling the amp's input with different resistors, thanks! I can't do spice yet (or any of the other cool things out there) but my Champ appears to have a 1M input so I guess I can simply try different resistors on the breadboard from output to ground and see what happens. Also, I did finally get my o-scope up and running so I don't know if that is something I could use for testing purposes or not.
As for the path to ground through R 7,8,9,10, no that wasn't deliberate. thanks fro pointing it out. I originally had a 22n coupling cap b/t Q2c and the tone stack but I pulled it out to see if there was a change. I didn't notice anything and the pot doesn't crackle when I turn it but perhaps I should just throw the cap back in there anyway.
Sure!
Try 1uF over C1 (great bass response) and lower value over C2 (3n3?) [emoji6]
In this case, I prefer to pan between that two values at the input..like the Meathead Deluxe
nice to see a BC549 up front. did you measure the hFE?
Quote from: Plexi on September 11, 2017, 10:42:19 AM
Sure!
Sometimes I do that panning thing too, but this happy accident just sounds so good that I think I will leave it for now.
Quote from: duck_arse on September 11, 2017, 10:47:07 AM
No Duck, I did not measure it but it is the magic transistor. Q2 can be anything, I have tried 2N5088, 2N3904, 2N2222, BC108, and an old Germanium NPN 2N1304 and everything sounds great as long as Q1 is that BC549
I would ask to the wise people: did the caps base/collector, increase in some way the overall gain?
It's a doubt I have since the first one knob fuzz I've built.
And as OP says, the gain in this design is wonderfull
R7, R8, (R9, R10) are a DC path to ground from Q2 collector...
Check out what I just noticed in the original schematic. Even though I didn't notice it I guess I figured a coupling cap was not necessary. I tried a coupling cap just now and realized it would be in series with my "high pass" cap in the tone stack, I'm not sure if that would affect the tone control action. Anyway, I will probably just leave out a coupling cap for now.
For extra credit, can anyone see the mistake in this portion of the schematic:
(http://a67.tinypic.com/2lvim80.jpg)
Quote from: Plexi on September 11, 2017, 04:17:47 PM
They actually DEcrease the overall gain, due to NFB action..
(they are used in such a way in high gain circuits to avoid oscillation at high frequencies...)
Quote from: Ben Lyman on September 11, 2017, 10:22:00 PM
Probably you mean the DC "unblocked" path through R8/R25/R5...
Seems like all the best "one knob" pedals have more than one just-don't-count-this-one knobs these days. Even the "one knob squeezer" on my pedal board has one! :icon_lol:
(https://s26.postimg.org/p455iioph/IMG_20161218_203418.jpg) (https://postimg.org/image/p455iioph/)
Quote from: antonis on September 12, 2017, 05:57:28 AM
No, something else is wrong with this... dead center, look again ;)
Two 6n8 caps in series would make C9=0.0034uF, not 0.0068uF.
Quote from: EBK on September 12, 2017, 11:12:53 AM
Bingo!
even so close to your [happy] birthday, antonis, no sausage!
DC unblocked path is a "design feature", no?
Quote from: duck_arse on September 12, 2017, 11:50:08 AM
It seems to me more like an "iniquity" between HP & LP filters... :icon_wink:
P.S.
On Friday (down-under local time) there will be free-beer party..
http://www.bigmuffpage.com/Big_Muff_Pi_versions_schematics_part1.html
Looking here ^ I see every EHX BMP is unblocked, until the bottom of the page I see the Ace Tone Fuzz Master BMP modded clone actually puts a 1uF between the collector and the tone stack.
I don't know if should I do the same or stick with the traditional EHX design. I don't want the series caps to interfere with the tone control but I guess 1uF is really not going to bring my 3n3 down much lower at all.
C11 1uF has been added and C6 changed to 4n7, everything still sounds good
(https://s26.postimg.org/fhvekvvu1/Meathead_w_mods.png)
So Ben, you made a 20% correction of C6 value for a 4% altering due to C11 ... :icon_eek:
nice work ben, i can't wait to hear it bro!
the only caveat i've found with dc coupling is sometimes it will smoke a pot or a resistor. i tend to use caps to minimize it, or try to minimize it. which leads to about 345 failures to every 1 circuit i figure is ok to let other folks mess with. ;)
swiping your schems to add to the archive... 66,000 some odd now in there!!
THATS A LOT OF #FUZZYGOODNESS!!!
rock ON brother
Quote from: pinkjimiphoton on September 13, 2017, 11:06:37 AM
Didn't notice "smoking" but DID notice "scratchy" behavior.. :icon_wink:
(on mechanically perfect pots..)
Quote from: antonis on September 13, 2017, 06:57:06 AM
Ya, you're right! LOL, it was the only cap I had
but it wasn't meant as a correction, it was just simply meant to make the tone control sound better. It's actually a change that I made a while ago but didn't get around to updating the schematic until now.
Quote from: antonis on September 13, 2017, 11:18:29 AM
often the scratchy behaviour is from the carbon track smoking. i just did it the other nite by accident, was so cool i did it a few other times. pot still works, but beginning of the track is wonky as hell!!
Another shitty phone vid demo:
Always loved this circuit. It's great for combining with other effects that needed gain and sustain like the Green Ringer.
I was always frustrated that I couldn't get it to do Gated or Splatty sounds like Ge Fuzzes though.
your legato chops are killer ;)
i love the envelope of the fuzz, how it compresses and expands. very very nice!! i love that "backwardsy" feel it gets on sustained notes.
nice work bro!!
Ben
are the collectors around Q1 1.6VDC and Q2 6 to 7VDC?
Gus, I haven't measured Q1 since it was on the bread but Q2 is about 5v, I was trying to get close to 4v5 because it seemed to sound the best around there when it was on the bread.
