DIY Stompboxes => Building your own stompbox => Topic started by: guidoilieff on August 06, 2018, 10:56:56 PM
Title: Weird transformer
Post by: guidoilieff on August 06, 2018, 10:56:56 PM
Hi. I found an old sony "combo"like this one:
(https://s33.postimg.cc/nscc0g497/modular-sony-mod-lbt-dr4cd-5tuner2-casseterasfuncionando-_D_NQ_NP.jpg) (https://postimg.cc/image/nscc0g497/)
It came with a stk 411-240e (schematic: https://forum.donanimhaber.com/stk411-220e-amfi-malzemeleri--111223906 (https://forum.donanimhaber.com/stk411-220e-amfi-malzemeleri--111223906) )
What most interest me is the transformer, but I don't know how these kind of transformers work. Does it have a specific name so I can make some research?
My goal is to make a guitar amplifier with it.
(https://s33.postimg.cc/pdrls9twr/IMG_0129.jpg) (https://postimg.cc/image/pdrls9twr/)
(https://s33.postimg.cc/f3p6t1jgr/IMG_0130.jpg) (https://postimg.cc/image/f3p6t1jgr/)
(https://s33.postimg.cc/68ociimyj/IMG_0131.jpg) (https://postimg.cc/image/68ociimyj/)
Title: Re: Weird transformer
Post by: merlinb on August 07, 2018, 03:28:42 AM
Quote from: guidoilieff on August 06, 2018, 10:56:56 PM
It's just an ordinary power transformer.
Measure the resistance between the pins to find the different windings (it looks like it has several secondaries, and maybe a multi-tapped primary for different world voltages). Then apply mains voltage to it (you know where the mains attached to the PCB, right?) and measure the secondary voltages.
Post by: anotherjim on August 07, 2018, 04:16:51 AM
It is a conventional transformer, but the arrangement is pcb mount as well as chassis mount - you normally only see one or the other provided for.
It does have a lot of secondary taps. You can easily see the primary side in the hatched area of the pcb silkscreen and the connection jumpers for 120/220/230-240 volt AC supply use.
Old STK amp modules are all very well, but I wouldn't want to use it unless I had a spare - you can't repair them.
Funilly enough, I have an STK rack mount stereo PA amp, the power stages are discrete. Maybe it isn't the same STK?
Post by: duck_arse on August 07, 2018, 10:53:30 AM
the transformer itself appears to have a mu-metal shield [the flat grey] and a copper "turn", meant to shield from hum and short hum, so the "hi-fi" audio remains the highest fidelity. I think.
Post by: PRR on August 07, 2018, 04:52:59 PM
Show some ID, please.
The boom-box has a model number which may lead to a service manual.
The transformer has numbers on it. The part-number might never be known outside the factory. But many Japanese irons also have the Volts and Amps printed on them.
It has the copper and iron (probably not Mu) because it is TIGHT inside a boombox. High-gain audio too close to high-power transformer.
It is not a bad plan to make a g-amp, but I suspect it will favor a very low impedance, similar to all the stock speakers in parallel. This may be ~~2 Ohms. Yes, a couple 4r or a quad of 8r is in that range.
Post by: thermionix on August 08, 2018, 01:14:01 AM
I'm genuinely confused (again).  How does a power transformer favor a speaker impedance load?
Post by: anotherjim on August 08, 2018, 05:43:59 AM
Solid state amps usually have limited DC supply voltage. 12v is common for bookshelf systems (so they can use the same cheap chip amps as your car audio) while many "separates" may have 30 or 40v. With low volts, the way to develop higher powers is to supply more current into the load. Lowering speaker impedance means you squeeze more current. 4ohm is the usual minimum.
Of course, you should never overload the amp circuit or its power supply, so the minimum speaker impedance should be written on the back panel somewhere.
Post by: PRR on August 08, 2018, 02:35:37 PM
At full power, the amplifier takes some voltage and draws some current. This is nearly proportional to load impedance. For totem-pole class B OTL, the power amp "acts like" a resistor about 6X the load impedance.
Check: for *example*, 48V (+/-24V) rails will support near 32 Watts in 8 Ohms (16Vrms, 45Vpp) and suck about 1 Amp. Power input is 48W, output 32W, efficiency 66%, which isn't ideal 78% but is very real-world. Apparent resistance is 48 Ohms which is 6X the 8 ohm audio load. The ratio is well above "1" because the two halves work alternately, peak of a Sine is well above average, and there is some pi in the mix. (You could derive this exactly, but I lost that matchbook, and in practical work "6*Rl" is close enough.)
I see four speakers and these days they are often nominal 6 Ohms. This suggests a single amplifier and 1.5 Ohm loading to get all the juice out of that iron. (I'd probably run two chips and two 4r speakers; the system was designed for lightly-clipped music, not HARD-clipped.)
Post by: guidoilieff on August 08, 2018, 10:37:06 PM
Quote from: PRR on August 07, 2018, 04:52:59 PM
Oh, that's why I couldn't find the model number on the front, sorry
Also, my dmm is not working properly on the AC mode, thats why the confusion also. I guess I'll have to buy another one. Maybe I'll check the fuse or some obvious damage on the inside.
Here are some more pictures
(https://s33.postimg.cc/cztohyoi3/IMG_0200.jpg) (https://postimg.cc/image/cztohyoi3/)
(https://s33.postimg.cc/mx4pb1j97/IMG_0197.jpg) (https://postimg.cc/image/mx4pb1j97/)
(https://s33.postimg.cc/f4e1j3nkr/IMG_0201.jpg) (https://postimg.cc/image/f4e1j3nkr/)
(https://s33.postimg.cc/a5qj4krhn/IMG_0202.jpg) (https://postimg.cc/image/a5qj4krhn/)
(https://s33.postimg.cc/44su7hhq3/IMG_0203.jpg) (https://postimg.cc/image/44su7hhq3/)
(https://s33.postimg.cc/qgqn0vojv/IMG_0204.jpg) (https://postimg.cc/image/qgqn0vojv/)
Post by: merlinb on August 09, 2018, 03:02:05 AM
Quote from: guidoilieff on August 08, 2018, 10:37:06 PM
Well that was easier than anticipated. See page 40:
http://diagramas.diagramasde.com/audio/Sony_HCD-GRX80_RXD8.pdf
Voltage are dotted around other pages so you have to work backwards to figure what they are at the transformer. Looks like about 10-0-10V, 0-15V, and a couple others.
Post by: guidoilieff on August 09, 2018, 04:57:07 AM
Quote from: merlinb on August 09, 2018, 03:02:05 AM
Yeah, I found it and then the power went off in my house
I cant find anywhere the voltages except for tolerances in capacitors
Post by: merlinb on August 09, 2018, 05:52:05 AM
Quote from: guidoilieff on August 09, 2018, 04:57:07 AM
(https://s15.postimg.cc/ktv0v86jr/fox.jpg) (https://postimg.cc/image/ktv0v86jr/)
Post by: guidoilieff on August 09, 2018, 07:48:22 AM
Quote from: merlinb on August 09, 2018, 05:52:05 AM
Thanks. We have different page numbers it seems.
Anyway. This part of the schematic shows the voltages for AC3 and AC4 but I don't understand what VH+ VH- and VL+ and VL- means on AC1 and AC2. Also don't know what VF stands for on the lowest winding on the schematic.
(https://s33.postimg.cc/pfquv7gt7/Clipboard02.jpg) (https://postimg.cc/image/pfquv7gt7/)
Post by: PRR on August 09, 2018, 04:36:37 PM
This is an ENORMOUS and tricky audio amplifier.
Aside from the housekeeping 5V 12V etc, there is The Power Amplifier, STK411 or similar. This takes *four* supply rails. Up to medium-loud it runs on +/-30V. When peaks get close to this, it switches to +/-60V. (This 60V must sag a lot, maybe to 40V at sustained full power in 2*8r.)
https://www.digchip.com/datasheets/download_datasheet.php?id=1347182&part-number=STK411-240E
Did you salvage the heatsink and enormous chip? PCB with huge caps? If not, it is going to be massive work to collect (genuine) parts to use this transformer the way it was intended.
A more practical re-purpose is to take the windings for +/-30VDC and power a LM3886 amplifier to about 40W/8r, a bit more in 4r, and you can run two for over 100W total. Something like these:
https://www.parts-express.com/yuan-jing-2-x-68w-lm3886-ne5532-audio-amplifier-board--320-6518
https://www.parts-express.com/dc-hs11118-aluminum-heat-sink-kit-1093-x-585-x-18mm--320-3280
Note the "amplifier" board also has the rectifier and big caps you need.
Post by: anotherjim on August 09, 2018, 04:47:05 PM
VH+ VH- and VL+ and VL-  are the supplies for the STK power amp module? For reasons Paul just mentioned.
VF. Historically, F or f has meant "filament". That could be valve heaters or filament lamps. Obviously not valve heaters here. Maybe it's an AC supply for panel lamps, display & backlights?
Post by: PRR on August 09, 2018, 05:10:27 PM
(https://s8.postimg.cc/9j6by229t/Sony-_HCD-power.gif) (https://postimg.cc/image/9j6by229t/)
Post by: PRR on August 09, 2018, 05:16:52 PM
Trace it around page to page to page. It IS the filament for the vacuum fluorescent display.
Most of those little housekeeping supplies are of no concern to us. We can easily derive +24V, +/-15V or almost whatever from the +/-30VDC rails. Implement the +60VDC (with a much smaller fuse) and power low-voltage tube-stuff or 48V Phantom. Or feed a voltage-quadrupler for serious small-tube-werk.
Post by: guidoilieff on August 10, 2018, 05:24:09 PM
Quote from: PRR on August 09, 2018, 05:10:27 PM
I guess the answer is no, but could it be possible to power only the main board and feed some audio level signal in the input of the stk411 (pin18/19 or pin 21/22) and expect some amplification on the outputs?
I don't mind shoving the whole main board inside a plywood cabin with a speaker
(https://s33.postimg.cc/e47nsvc0r/IMG_0216.jpg) (https://postimg.cc/image/e47nsvc0r/)
Main PWB?
(https://s33.postimg.cc/jfmkdm8e3/IMG_0219.jpg) (https://postimg.cc/image/jfmkdm8e3/)
Power amp
(https://s33.postimg.cc/jsdyk73mz/IMG_0218.jpg) (https://postimg.cc/image/jsdyk73mz/)
Power block
(https://s33.postimg.cc/oea2sjhgb/IMG_0221.jpg) (https://postimg.cc/image/oea2sjhgb/)
Post by: PRR on August 10, 2018, 07:23:39 PM
Yes.
EDIT!!!   Cut jumpers JW172 JW173 JW174.
EDIT!!!  Do NOT cut jumper 173!!
Feed 0.5V signal: L to JW175, Gnd to JW176, R to JW177
(https://s8.postimg.cc/8hya3yyb5/Sony-_HCD-_Hack.gif) (https://postimg.cc/image/8hya3yyb5/)
Post by: guidoilieff on August 11, 2018, 02:23:44 AM
Quote from: PRR on August 10, 2018, 07:23:39 PM
Yes.
THANKS!!!!!
Post by: PRR on August 11, 2018, 09:42:44 PM
MISTAKE!!!
The drawing is right, my text was wrong.
Post by: guidoilieff on August 12, 2018, 03:07:02 AM
Quote from: PRR on August 11, 2018, 09:42:44 PM
MISTAKE!!!
That's fine. Thanks for the warning!
It works!!
Post by: guidoilieff on August 13, 2018, 04:54:35 PM
Yes.
Hey, im sorry. I said its working because the ic got warm (37/38 centigrades) and when I discharged the capacitors it made a big spark but now when I connected a speaker nothing happened.
I plugged the fan to check if the amp was on without a power button but its not.
Do you think the problem may be that I have no way to switch it on like this?
this is what I found on page 70:
7-25. IC PIN FUNCTIONS
IC501 MASTER CONTROL (M306622 MA-A01FP)
Pin No.  Pin Name         I/O   Function
1          STK-MUTE        O      Power amp ON/OFF signal output
2          POWER            O      Power ON/OFF signal output
3          F-RELAY           O      Front speaker relay control output
(https://s33.postimg.cc/eln8m16mj/on_off.jpg) (https://postimg.cc/image/eln8m16mj/)
(https://s33.postimg.cc/v9eqoitob/on_off_2.jpg) (https://postimg.cc/image/v9eqoitob/)
(manual: http://diagramas.diagramasde.com/audio/Sony_HCD-GRX80_RXD8.pdf (http://diagramas.diagramasde.com/audio/Sony_HCD-GRX80_RXD8.pdf) )
Post by: guidoilieff on August 17, 2018, 09:27:45 PM
Yes.
I'm sorry to insist but do you think it will have trouble powering on? Thanks
