Hi all,
I'm confused on the description of the GGG/RG Neutron Power Options..
I'm planning on using the 'Charge Pump with C15,16,17,18 Caps'.
--Question: When using the 'Charge Pump Option', do I still need to leave or can I omit the 'Optional Bipolar Single Battery Caps' C10,11,12,13 ??
Just not sure if both options components are needed on the board when choosing Charge Pump..?
Here is the schematic:
(https://i.postimg.cc/Y4WqGdtx/Neutron-Filter-GGG.jpg) (https://postimg.cc/Y4WqGdtx)
Thanks for any help
From what I have since learned, when using the 'Charge Pump Option with caps C15,15,17,18'.. it is advised to still install caps C10,11,12,13 as they function as power filtering which won't hurt and probably benefit.
