Does anyone know where to find Eagle components (valves/tubes), in the libraries? I have looked in the stock ones, MB's and GM's... I may be just missing them.. But I need a diagram for a 12AX7 family... PCB (pin) mount socket.
Thanks in advance!
MC
Quote from: italianguy63 on August 14, 2019, 10:22:54 AM
Thanks in advance!
MC
I've got them somewhere. I'll drop you a PM
PM sent, cant figure out how to add an attachment here :(
I haven't seen the PM yet?!
You can email to gdmc@inbox.com please.
MC
Sent
Got it thanks!! Now, I have to figure out how to use it!!
Got it loaded.. but not seeing the "heater" connections.. I guess I need to play with it awhile and try to figure it out! Thanks!
MC
They are in the madbean library, they have their own folder.
It's called tubes!
Quote from: mth5044 on August 14, 2019, 04:37:35 PM
It's called tubes!
I did not see it.. but my MB lib is older (2012?)
Do you maybe have a link to the newest?
MC
http://www.madbeanpedals.com/forum/index.php?topic=25194.0
Quote from: mth5044 on August 14, 2019, 11:52:18 PM
Thanks... forgot my login.. working on that.
Looks like the library PMowdes sent me will work. Thank you again!!
Apparently the problem is you have to hit the "Invoke" button in Eagle to add the heater connections. (Now, that was intuitive!! - not!)
It's ugly.
Does anyone happen to have an Eagle "Valve" schematic (with heaters) that they could share a picture of so I can see what the "detached" heaters are supposed to look like on the page??!!
Thanks again!
Eagle is always a learning process.
MC
Quote from: italianguy63 on August 15, 2019, 02:03:18 AM
It's ugly.
Thanks again!
MC
The invoke command is pretty standard in Eagle, especially for IC power connections.
If for instance if you use a 3p4t switch and you accidentally delete one of the switch elements you can use the invoke command on one of the associated parts to recall the missing one.
I learn a little more about Eagle each project I do.
;D
Direct link to library: http://madbeanpedals.com/downloads/MBP_2017_v3.0.zip
https://www.diystompboxes.com/smfforum/index.php?topic=117168.0
You've just summarized why I never got into Eagle :P
Quote from: bean on August 15, 2019, 10:47:38 AM
Thanks Brian!!
